Replacing exhaust flexis
webster444
Post by webster444 » Sat Mar 15, 2014 10:54 pm
Both my exhaust flexis between the cats are damaged right through and now leaking. With MOT time coming up I will need to replace them.
Anyone know where is best to buy the replacement flexis?
What grade of steel is the exhaust so I know what filler wire to get for my mig?
Ta much
webster444
Re: Replacing exhaust flexis
Post by webster444 » Mon Mar 17, 2014 8:46 pm
Anyone any ideas?
WilkinsonRS4
Post by WilkinsonRS4 » Mon Mar 17, 2014 9:45 pm
Instead of putting new flexis back on why not weld in stainless steel pipes hence no corrosion ever again and better air flow!!!
Modified standard exhaust Modified deflapped inlet manifold ported and polished
Head and valve decoke Performance K&N panel filter. Remapped. Lowered slightly (20mm) on KW performance springs Widened on 10mm spacers.
webster444
Post by webster444 » Wed Mar 19, 2014 1:20 pm
Id prefer to stick flexis in again so I dont have any potential vibration related cracks forming
WilkinsonRS4
Post by WilkinsonRS4 » Thu Mar 20, 2014 4:14 pm
webster444 wrote:Id prefer to stick flexis in again so I dont have any potential vibration related cracks forming
Ye your right!! I need to locate flexis too I've found a place in Liverpool that I've spoken too but they need dimensions and OD have you got the dimensions and spec etc??
toyneg
Post by toyneg » Fri Mar 21, 2014 10:08 am
i had mine checked at a local (ish) exhaust specialist, he was going to charge £150 all in to replace both but he was good enough to be honest and said although slightly scuffed/damaged they weren't leaking so he said not to bother :)
webster444
Post by webster444 » Fri Mar 21, 2014 1:12 pm
Not sure on the dimensions of them, 2.5" diameter is all I know at the moment. Im offshore at the moment so will have to have a look when I get home.
Mine are definitely holed right through so will fail an MOT.
Anyone know what grade of stainless welding wire is all right to use to a varied range of stainless grades?
WilkinsonRS4
Post by WilkinsonRS4 » Mon Mar 24, 2014 12:56 am
webster444 wrote:Not sure on the dimensions of them, 2.5" diameter is all I know at the moment. Im offshore at the moment so will have to have a look when I get home.
Go to jcwhitney.com mate
Users browsing this forum: Bing [Bot] and 69 guests
