Engine Start Stop
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Brooner
Engine Start Stop
Post by Brooner » Fri Dec 06, 2013 3:19 pm
Can you permanently disable the start stop feature using Vag Com as my wife is getting the a new car with the feature as a standard and according to the dealer cannot be disabled other than using the button inside but this is reset when the journey is finished.
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
TimDogg
Re: Engine Start Stop
Post by TimDogg » Sun Dec 15, 2013 8:45 pm
Apparently you can't, sorry - might be some fuse you could pull but that's getting technical.
'56 ST220 (Sold)
'97 ST24 (Sold - loved lots)
Brooner
Post by Brooner » Mon Dec 16, 2013 5:37 pm
Thanks yes thought as much the wife will just have to remember to press the disable button at the start of each trip
Ponyboy
Post by Ponyboy » Mon Mar 10, 2014 11:39 am
Why would you want to disable it? I had it on my A4, worked well and was quite pleasant at lights, relaxing even, lol.
Brooner
Post by Brooner » Mon Mar 10, 2014 12:23 pm
Just a pain as I always think the engine has stalled plus the extra wear and tear on the starter motor going on and off all the time and if turning a t a junction would be a pian with the 21" wheels the savings in fuel and emissions would be very small
Ponyboy
Post by Ponyboy » Mon Mar 10, 2014 2:14 pm
Brooner wrote:Just a pain as I always think the engine has stalled plus the extra wear and tear on the starter motor going on and off all the time and if turning a t a junction would be a pian with the 21" wheels the savings in fuel and emissions would be very small
:thumbs:
nigelw1982
Post by nigelw1982 » Tue Dec 23, 2014 10:08 pm
you can do it with VCDS you need to do the following
19 - CAN Gateway
Adaptation - 10
From drop down menu select (1) select start stop minimum temperature
in new value box put 50 instead of -50
Click do it and add to log
From drop down menu again select (2) select Start Stop maximum temperature
click do it and add to log
Voltage method
19 - CAN Gateway
Adaptation - 10
from menu select start stop voltage limit
new value enter 12 as default stored is 7.6v maximum of 12.1v
you could have Acc/Start Auth. Control module fitted to your car (address 05, HW:5Q0-959-435)
This controller has only one adaptation channel whose sole function is disabling Stop/Start. The adaptation channel descriptor is Deactivation of start-stop function and default setting is not active. Change this to active
Hope this helps
Return to “DTC / VCDS”
