TPMS sensors mass suicide..?
Re: TPMS sensors mass suicide..?
Mine kept coming on so i kept re-setting as the pressures were not dropping, so when i changed the wheels and put the spacers on i transferred the sensors but one was really loose almost falling off, when all was done i didnt have to re-set anything the light was off as soon as i turned on the ignition now it has not come on since seems to be sorted
Present: Red RS4 Cab, Yamaha MT01 turbo, Merc sport Vito, Corsa
Previous: Sabb Aero 2.0 turbo (Hirsch performance upgrade) M3 E46 Cab, M3 Coupe, 470 hp Subaru type RA ( Redline featured), 330 sport, Subaru Sti Bug eye 350hp Subaru UK 300, Mondeo ST V6, XR4X4, XR4i ( big valve engine from "specialized engines"), 2.8i capri, Renualt 5 turbo, Plus a few sheds inbetween
The TPMS is staying off so the info was right foranyone thinking of doing the same
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Re:
guffy wrote:I disabled my TPMS using VAGcom last month, i googled it, easy fix to implement.Iain_S4 wrote:.
How do you turn off the TPMS so that I stop getting that annoying beep on start up? I looked in the manual but couldn't find anything. Can it be done by VAGCOM?
Select -> 17-Instruments -> Adaptation -> Channel 61.
Subtract 512 from whatever value you find there.
I have just had to done this, this morning due to me putting 20s on
Our car is 06 June no probs with any sensors as yet purchased at 6 months old and not replaced any as yet.
Hi all,
I have a problem. Yellow warning light with a line through it on the dash - from startup.
VCDS gave a fault. I forget the fault code- i left it at home, but it was a general fault that said the MIL was on. Nothing about a particular component.
I went into measuring blocks. I can only see the pressure for position 2.
1,3,4 are all not reading pressure or temperature.
Any ideas? I read about the antenna, but if one is working ??
Thanks!
Thanks!
06 - B7 RS4 Saloon - Milltek Non-Res Valved. BMC Filter.
Users browsing this forum: No registered users and 181 guests
