Sticky for pics/vids RS6 C5
- Weiß-sechs
- 5th Gear
- Location: Everywhere & nowhere baby, that's where I'm at...
Whats the welded up box do? The air filters are in the ducting from the intakes by the looks of it so not sure what's in the shiny box; anyone know?
Other than looking utterly gash, the only thing I can think of is water / meth injection.
- Weiß-sechs
- 5th Gear
Shoppinit wrote:Other than looking utterly gash
Or me alsoWeiß-sechs wrote:Shoppinit wrote:Other than looking utterly gashglad I'm not the only one then....
950 nm torque!
This.
/EDIT - it seems to be available again!
This was the first mock-up of that intake system. It was documented over on RS6.com but I'm not sure what happened to that site.Shoppinit wrote:...the only thing I can think of is water / meth injection.
The overall specs:
034-Sourced Blueprinted Race Short Block
KW Coilovers
Forged Pistons + Rods
8.5:1 Compression
Ported + Clipped Stock Turbos
Rennen Wheels + Custom Center Caps
FMU Custom Full Exhaust
FMU Custom 1600 hp Fuel System
Electronic Boost Controller
FMU Custom Tune
Okada Projects Ignition Coils
Ported Intake Manifold
Intake Manifold + SwainTech Thermal Coating
FMU Custom Phenolic Spacer
Exhaust Manifold + SwainTech Thermal Coating
FMU Custom Intake
Powdercoated Valve Covers
FMU Custom Catch Can + Crankcase Vacuum Venturi
FMU Custom Oil + Transmission Coolers
FMU Custom Intercooler
Powdercoated Brakes
600hp 600torque
KW Coilovers
8.5:1 Compression
FMU Custom Tune
FMU Custom Intake
Powdercoated Brakes
600hp 600torque
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
- Weiß-sechs
- 5th Gear
Seems like a hell of a lot of money/fannying for just 600 bhp.......the 1600 hp fuel system is somewhat underutilized
Stock turbo housing = 600HP.Weiß-sechs wrote:Seems like a hell of a lot of money/fannying for just 600 bhp.......the 1600 hp fuel system is somewhat underutilized
Where have we heard that before...
- Weiß-sechs
- 5th Gear
Agreed, we've heard it many times before but only from one source as far as I'm aware.
Point being, why go to the enormous expense of completely rebuilding an already strong motor good for up to 750-800 bhp on standard crank/rods/pistons and not make full use of the potential?
Beer and hookers seems a far more enjoyable money waster to me....
Weiß-sechs wrote:Agreed, we've heard it many times before but only from one source as far as I'm aware.
Is that speaking from experiance??
950 nm torque!
What else would he be speaking from?
- Weiß-sechs
- 5th Gear
My arse maybe?bam_bam wrote:What else would he be speaking from?
If you're speaking about hookers from you're arse then you should probably try a female one next time.Weiß-sechs wrote:My arse maybe?bam_bam wrote:What else would he be speaking from?
- Weiß-sechs
- 5th Gear
Edited; no, you're welcomebam_bam wrote:If you're speaking about hookers from your arse then you should probably try a female one next time.Weiß-sechs wrote:My arse maybe?bam_bam wrote:What else would he be speaking from?
Anyhoo, I've got some Tennants Super and Poxy Roxy to get back to
