RS4 B7 Disc Life Poll
Re: RS4 B7 Disc Life Poll
Mine have done 35k and still ok
- John Johnson
- 5th Gear
Not guilty ...not clicked nuffinkTimster wrote:So why did you click < 5k then ?John Johnson wrote:Looking at my paperwork mind have done just under 60k and swapped out , used a couple of sets of pads though
Current toys in the garage
B7 avant in Daytona with ceramics and a few other goodies and lowwwww miles
Ur quattro. lago Blue
Ur quattro. Mars red
Rs1600i
Transit custom sportvan
http://youtu.be/FWBUl7oT9sA
Rs1600i
- John Johnson
- 5th Gear
So reading between the lines then you've been informed 5k for a set of discs and pads is quite normal wear and tear
Rs1600i
Rs1600i
42k on the original set - they need replacing soon though
Indeed!John Johnson wrote:So reading between the lines then you've been informed 5k for a set of discs and pads is quite normal wear and tear
2007 Sprint Blue RS4 (B7) Black Optics, Solar Sunroof
They must think your stupidSo reading between the lines then you've been informed 5k for a set of discs and pads is quite normal wear and tear
- John Johnson
- 5th Gear
You forget the "<beep>" bit and "let's take the piss out of this soft kent "
Rs1600i
Rs1600i
mines on 56k just about to replace front discs and pads
- PetrolDave
+1Silas wrote:They must think your stupidSo reading between the lines then you've been informed 5k for a set of discs and pads is quite normal wear and tear
Whoever said that the discs only last 5k miles is talking out of somewhere that the sun doesn't shine.
Front changed at around 35k miles, rear still original at 65k
2007 Phantom black RS4 B7 with DMS twist - limiter off - spacers - windows tint - non-res valved milly black tips
986 Boxster S
Daily: C7 A6 2.0l tdi (now with 199bhp - 460Nm)
'Find what you love, and let it kill you' Bukowski
986 Boxster S
- surfpunkian
55k original front, 17k on current and looking good!
Daytona Grey RS4 B7 Saloon, carbon cleaned, titan alloys, LEDs, deflap manifold and stage 1 map, Bilstein PSS9 coilover set up, 8mm spacers, lowered.
Your all puffs,first set at 27k and second set just gone on @ 51k,you do realize there shot when you can feel a small 1mm lip on em? I've driven ashes car and it's deffo not pad deposition that Ive experienced now n again on mine,there definatly warped,it's clearly got them stumped as to the cause but to hear that 3k out a set of discs n pads is within the realms of normal as part of the diagnosis is a tad lower than you would expect in both disc life and quality of fault diagnosis.Imo they've been very good regarding goodwill for a car well out of warranty but.............it's reasonable to expect more than a few k from new discs and pads or at least a valid plausible technical explanation of another issues causing it!
- NJMAudiRS4
I just went through the paperwork and my fronts were actually replaced at 33k but this set is still going at 93k - I can't find any record of the backs being done, surely they can't last that long? Obv ots now time to replace them all
Users browsing this forum: tupi154 and 129 guests
