Yellow warning sign
Markmyatt7
Yellow warning sign
Post by Markmyatt7 » Tue Feb 11, 2014 10:46 am
Hi all,
Just went out today and saw this warning signal come on the display. Checked all external lights and they are fine. Looked in drivers manual and no mention of this at all ( unless I missed it).
Has anyone got any ideas?
Current Car: 2014 Nissan Quashqai 4WD (it's not my fault)
Previous Cars: 2006 B7 RS4 - Phantom Black
2010 BMW 123d Coupe M Sport
2004 Honda Civic Type R
2002 VW Golf 2.8l V6 4 Motion
Surrey Sam
Re: Yellow warning sign
Post by Surrey Sam » Tue Feb 11, 2014 11:15 am
It's the car saying turn me over :D
In all seriousness, it looks like a headlamp levelling problem. It will probably have thrown a fault code to indicate which end you should be looking at, alternatively you could look for the plastic arms which attach to the suspension to see if they are all in order. There will be one per side and one per axle, I think the front one is passenger side and the rear one on the driver's side.
Madmonkee
Post by Madmonkee » Tue Feb 11, 2014 11:24 am
Markmyatt7
Post by Markmyatt7 » Tue Feb 11, 2014 11:27 am
Madmonkee wrote:http://nickscarblog.com/diy/how-to-fix- ... on-an-audi
Covers it pretty much.
Nice one will have a look when it stops snowing.
Timster
Post by Timster » Tue Feb 11, 2014 12:00 pm
Pretty sure my rear sender is on the NS on my Avant... but I haven’t been under there for a while, so could be mistaken.
Madmonkee
Post by Madmonkee » Tue Feb 11, 2014 12:10 pm
VCDS it first, that will at least narrow down the fault to, sensor, headlight motors, or bulb/ballast. You can start with the cheapest and work your way around.
http://forum.rs246.com/viewtopic.php?t=83740&start=0
Im at the ballast replacement stage at the mo. Bulbs can be changed without removing bumper but its a real pita!
RS04YOB
Post by RS04YOB » Tue Feb 11, 2014 12:59 pm
I had this sign for me it was the leveling system that went wrong it needed replacing. And then a few months ago I had to go through the self leveling process again could be a few things
Markmyatt7
Post by Markmyatt7 » Tue Feb 11, 2014 3:42 pm
I'll have to get it booked into an Audi dealer to get diagnosed. I'm not very technical minded.
monkey_in_shoes
Post by monkey_in_shoes » Tue Feb 11, 2014 6:39 pm
Who said nothing goes wrong at 100k!
coffey555
Post by coffey555 » Tue Feb 11, 2014 7:13 pm
Things always go wrong with these things regardless of the mileage!
Misano Red RS4 B7 Avant
R1RS4
Post by R1RS4 » Tue Feb 11, 2014 8:30 pm
coffey555 wrote:Things always go wrong with these things regardless of the mileage!
+1
RS4 B7 Avant,2007
Metallic black, Black optics pack, Black gloss Wheels, Milltek black tipped -valved, MRC Installed TTS Supercharger 610ps/626nm, MRC stage 3 remap, CAF, DRC/SS+ with H&R spacers, carbon race splitter, carbon trim
Ginors4
Post by Ginors4 » Tue Feb 11, 2014 10:24 pm
Yep. I had this sign on my old a4. Was an adaptive headlight problem with mine although no visual problems it flagged up on the Vag Com. Was about £400 to fix just to get the light out.
Gone and miss very much
B7 RS4 Avant Misano Red, lepsons 2-tone black shadow chrome rims, KW coilovers, AMD Stage-1 with valved non-res milltek catback.
Ginors4
Shaners4
Post by Shaners4 » Sat Feb 15, 2014 11:34 pm
I still have this on my B7 saloon, Since removing both headlights, prising them open to spray the insides black and fit new bulbs I've had this light on, so its obviously something I've done within the headlight itself. I've put up with it for 6 months so far but now need to replace one of the headlight lamps as it keeps going off when driving so I'm determined to get to the bottom of the cause. Diagnosis machine doesn't bring up fault and yes your correct the symbol isn't in the hand book. :(
Surrey Sam
Post by Surrey Sam » Sat Feb 15, 2014 11:41 pm
Shaners4 wrote:Diagnosis machine doesn't bring up fault and yes your correct the symbol isn't in the hand book. :(
Which diagnostic system are you using?
Users browsing this forum: Bing [Bot] and 205 guests
