Exhaust comparison - Oem vs non res vs res
sakimano
Re: Exhaust comparison - Oem vs non res vs res
Post by sakimano » Thu Jan 02, 2014 8:35 pm
watts6087 wrote:http://www.youtube.com/watch?v=Y6d6JGdaKtA
Here is the sound of mine :)
I see your one flyby...
https://www.youtube.com/watch?v=bTsiKwjAVpY
and raise you a 2-3-4 rip through the gears...
https://www.youtube.com/watch?v=VCEWZjl ... ata_player
RIV
Post by RIV » Thu Jan 02, 2014 8:37 pm
anyone's can rev to 8600. Thing is...would you want it to? I think your piston rings will br crying for mercy after too much of that. The good news is though you'll now have a 007 like smokescreen defense (free of course)
Fook you do talk some bollocks :ban:
sakimano
Post by sakimano » Fri Jan 03, 2014 8:18 am
Ban... For what. For pointing out a fact? Moron.
Audi redesigned the engine almost entirely, pistons included, in order to support the raised rev limit and to address a weakness the B7 engine had (related) .
Silas, go back to the detailing threads and stick to something you have a fking clue about. Otherwise every time you open your mouth you just fill the forum with the smell of <beep> from the bullshit you spew. You add nothing factual or technical. Just inflammatory crap. Useless. You even have a <beep> sense of humour. What are you good for?
Now go polish your car and get ready for santa pod. I can't wait for you to run 13.3 like a bitch.
RIV
Post by RIV » Fri Jan 03, 2014 10:30 am
Ha ha!!you really are a total knob
PetrolDave
Post by PetrolDave » Fri Jan 03, 2014 7:10 pm
sakimano wrote:anyone's can rev to 8600. Thing is...would you want it to? I think your piston rings will br crying for mercy after too much of that. The good news is though you'll now have a 007 like smokescreen defense (free of course)
I suggest you ask MRC how many of their customers with the rev limit raised to 8600 have had any problems...
The answer might surprise you; when I asked the question (before agreeing to it) the answer was a VERY small number... zero, zilch, zip, nada, none.
RIV
Post by RIV » Fri Jan 03, 2014 7:21 pm
Exactly!!after all it's built to be a high revving v8, if you can charge them beyond 600 ps with no problems, this very small mod is a drop in the ocean in comparison.
Rw@@dy
Post by Rw@@dy » Fri Jan 03, 2014 9:10 pm
Guys not sure how this thread turned into this! Only asked about comparison of exhausts...
mf51y
Post by mf51y » Fri Jan 03, 2014 10:51 pm
Mmm ill try my luck again...I guess that many rs4 owners first plugged their vac lines and had sporty exhaust all the time which is ok.......when they fitted their milltek catback how much of a bigger grin did you get bearing in mind the drone inside?
Twice as loud? Little bit up to say 3000rpm loads more higher up etc etc ? As you can tell ive yet to hear one apart from YouTube :) :thumbs:
Mugello blue avant black optics...Nearly standard...milltek resonated valved, spaced 10 rear 8 front☺
Private Pile
Post by Private Pile » Fri Jan 03, 2014 10:53 pm
Guys,
Has anyone just had the precat and centre silencer removed from the standard exhaust? I'm considering this option along with the exhaust flaps fixed open in order to liberate some more noise, hopefully without the drone!
Cheers and happy new year! :beerchug:
PP
Covkiller
Post by Covkiller » Fri Jan 03, 2014 11:26 pm
JC Weldfab can remove your pre cats:
http://www.jcweldfab.co.uk
toyneg
Post by toyneg » Fri Jan 03, 2014 11:29 pm
mf51y wrote:Mmm ill try my luck again...I guess that many rs4 owners first plugged their vac lines and had sporty exhaust all the time which is ok.......when they fitted their milltek catback how much of a bigger grin did you get bearing in mind the drone inside?
yep I 1st plugged my vac lines like you said which is a decent mod but before I went down the new exhaust route I got the misses to do some overtakes in mine while I drove her car on a duel carriageway and it wasn't massively impressive from the seat of another car. I did the same thing after getting a non res fitted along with the pre cats and wow what a difference. I also love the popping and crackling the exhaust makes. the car turns heads now on a different level to when it was OEM and I love it.
sakimano
Post by sakimano » Sat Jan 04, 2014 2:08 am
Private Pile wrote:Guys,
PP
That's very popular over here. Guys replace the centre resonator section with an X Pipe or H pipe
Here's a video comparing my totally stock avus vs a phantom black car with precats gutted + h-pipe/resonator delete
https://www.youtube.com/watch?v=fjdlEU483no
PetrolDave
Post by PetrolDave » Sat Jan 04, 2014 12:04 pm
Rw@@dy wrote:Guys not sure how this thread turned into this! Only asked about comparison of exhausts...
If you think threads on here go bad, you need to read audizine - there's often some real venom on there!
Private Pile
Post by Private Pile » Sat Jan 04, 2014 11:53 pm
Cheers Sakimano :wink:
sakimano
Post by sakimano » Sun Jan 05, 2014 5:14 pm
Once again, you're talking <beep>.
The fact that the rods hold up and don't grenade the engine with big power doesn't mean all is well and that they can handle it. Your ignorance = my bliss. Good luck silas!
Users browsing this forum: Majestic-12 [Bot] and 109 guests
