Exhaust comparison - Oem vs non res vs res
PetrolDave
Re: Exhaust comparison - Oem vs non res vs res
Post by PetrolDave » Tue Dec 31, 2013 5:18 pm
adsgreen wrote:Jesus h Christ... It was said tongue in cheek hence the smiley...
Sorry missed that - I saw the word "diesel" (the fuel of the devil) and the red mist descended :beerchug:
Happy New Year to all on here, especially adsgreen
:drink: :drink: :drink: :drink: :drink: :drink: :drink:
adsgreen
Post by adsgreen » Tue Dec 31, 2013 5:27 pm
And to you Dave :)
Was a bit worried as you're always a voice of sanity and reason on here
(I'm a victim of red mist too... as you've seen in other threads ;)
Rw@@dy
Post by Rw@@dy » Tue Dec 31, 2013 5:47 pm
PetrolDave wrote:
adsgreen wrote:The only bad noise is the resonant drone and this is between 1500-2200 ish rpm.
Slight tweak to driving style and it's not a problem.
I'd seen this said a lot before I went for a non-res valved in the Summer, and have to say after 6 months I think "slight tweak" is a major under statement.
Around town and when just pottering (e.g. on holiday) I used to spend 90% of the time between 1500-2200 rpm in non-Sport mode using the torque, but I just can't do that now as the drone is, to my ears (and especially to my wife's ears),really intrusive. So I've had to adopt a completely different driving style when pottering, instead of being in 5th or 6th gear I now use 3rd in 30 limits and 4th in 40 limits in order to get the revs above the drone (2200rpm+).
Needless to say whenever I'm out on my own it's Sport mode on and grin all the time. :jump:
But I have to say that IMHO a non-res has deleted one element from the RS4s armoury - it can no longer comfortably waft along in a high gear in town. That's been especially noticeable for me this year as we've had 2 close family funerals where I've had to be the first car behind the hearse & limo, and sitting in the drone region was too noisy but sitting above the drone zone got looks for using "such high revs". :FIREdevil:
This is exactly what I was expecting, I had exactly the same problem in my golf and you've made my mind up that if I change exhaust it will be a res. thanks
adsgreen
Post by adsgreen » Tue Dec 31, 2013 7:44 pm
By all accounts don't expect miracles from the res - Whilst in theory it should sort it, many have said that it's around a 20% improvement.
Worth getting an opinion from a res owner.
sakimano
Post by sakimano » Tue Dec 31, 2013 11:08 pm
PetrolDave wrote:[
Yes drone sucks .
Resonated vs non res doesn't really matter if that helps. Drone is drone, and is primarily determined by the engine and exhaust system design. Cats and resonators may make it slightly worse actually. Some people say to get resonators. Ignore them lol...you will just end up poorer. Audi spends a fortune eliminating drone. Aftermarket exhaust companies don't.
Strangely it is not louder outside... Just inside. Many people don't think it's drone they just think their exhaust is loud there in that rpm range. It's not. Same volume outside through 1000 to 4000 but inside you get the drone.
mf51y
Post by mf51y » Wed Jan 01, 2014 1:02 am
Iam running with the vac lines securely plugged so valves open all the time, its a great sound no complaints from any drone. Typical me would love a non resonated Milltek...any comments/regrets from owners who have experience of the same transition such as noise inside verse the magical sound from outside?
Mugello blue avant black optics...Nearly standard...milltek resonated valved, spaced 10 rear 8 front☺
rob-s
Post by rob-s » Wed Jan 01, 2014 9:50 am
I also stuck the tubes of the valves and am 100% happy with the sound now. Not too much but enough to enjoy the V8 sound:) ..and no drone at any revs.
Daytona Grey B8.5 & Guards Red 981 / Ex.Audi RS4 B7 Sedan, Daytona Grey.
ROY
Post by ROY » Wed Jan 01, 2014 7:12 pm
I had a Milly Non-Valved Non-Res and it did my bloody head in, I couldn't drive anywhere without massive drone - swapped in a Resonated Section and it was fine
Great sound and ideal for everyday driving :thumbs:
Gone but not forgotten boohoo !!!
RS4 Sprint Blue Avant on Dyno after Carbon Clean http://youtu.be/7lsBbmmaDQc
Covkiller
Post by Covkiller » Wed Jan 01, 2014 9:57 pm
Mines a Non Res Valved Milltek, yes there is a drone with valves open or closed. However with my Milltek non cat downpipes fitted there is no drone at all. With the valves closed the exhaust is quieter too (confirmed by wife) and like gods thunder with the valves open.
watts6087
Post by watts6087 » Thu Jan 02, 2014 12:45 am
spikeyboy101
Post by spikeyboy101 » Thu Jan 02, 2014 2:47 pm
What ever you do get - remeber that it is louder when first fitted until it beds in.
When i got my Milly Non-Res Valved i couldnt stand driving it as it gave me a headache from the drone, however after a few hundred miles its fine, as others have said just drive around the 2,000 rpm drone area.
Hit 4,000 rpm and make sure the S button is pressed :)
toyneg
Post by toyneg » Thu Jan 02, 2014 3:42 pm
i have a non-res, non valved Milltek and I am in the same opinion as Dave on this one - You can drive around the loudest part of the drone but it does take some getting used to compared to how you might have driven the car before using the low down torque.
Rw@@dy
Post by Rw@@dy » Thu Jan 02, 2014 6:02 pm
Great feedback all, thank you
PetrolDave
Post by PetrolDave » Thu Jan 02, 2014 6:50 pm
ROY wrote:swapped in a Resonated Section and it was fine.
That's what I'm going to have to do - mind me asking how much it cost to have it swapped? (Did try to PM you but got the dreaded SQL Error).
sakimano
Post by sakimano » Thu Jan 02, 2014 8:26 pm
Ian_C wrote:Fecking hell, yours revvs to 8600!!!! :bowdown:
Must admit Dave, I'd forgotten you'd gone non res - rock on!
anyone's can rev to 8600. Thing is...would you want it to? I think your piston rings will br crying for mercy after too much of that. The good news is though you'll now have a 007 like smokescreen defense (free of course)
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 115 guests
