help over fueling problem??
Re: help over fueling problem??
Sounds like misfire problem to me. Could be dodgy plugs or collpack failer
- PetrolDave
A VCDS fault code scan would be a good place to start.
+1 - probably not a case of too much fuel but duff spark.Lukes3 wrote:Sounds like misfire problem to me. Could be dodgy plugs or collpack failer
First thing would be to switch the plug/coil pack to a different cylinder and see if the diagnostics reports a different cylinder.
If so then it's either the coil pack or plug - move the coil pack back to cylinder 5 and re run test. If it goes back to cylinder 5 then it's the coil pack, if not then the plug.
If it stays on cylinder 5 after moving the pack and plug then it actually could be the injector.
Note: Just noticed more than one cylinder affected. Definitely need the details from vcds to see what's going on.
Users browsing this forum: Google Adsense [Bot] and 136 guests
