the RS5 from OZ ...
marzz
Re: the RS5 from OZ ...
Post by marzz » Mon Dec 23, 2013 8:37 am
sakimano wrote:What have they done with the belt? 5 or 6 rib?
belt is only 5 rib, it's almost physically impossible to fit another rib, unless we relocate the main cooling pipes and cut some staff out to fit thicker pulley...
so far so good, the belt is shorter than in R8, new tune is going in as we speak ...
marzz - my RS5 build
marzz
Post by marzz » Wed Dec 25, 2013 11:55 am
just got my tune tweaked and German Motoring TCU upgrade for stronic installed yesterday at CPC, while PESed, the stronic got a bit jerky due to obvious reasons, will do some more driving and see how it all goes, also may find some time during this Christmas to do the cheap apikol upgrade, LED interior swap and perhaps something else ... (?!)
also, had this f***n lever sensor error for a while now (prior PES install) so ordered all parts from stealership in Poland for third of the price including shipping, so we have to strip the stronic some times in January as well, then hitting the strip and track ...
Post by chunky79 » Wed Dec 25, 2013 11:58 am
Amazing build.
marzz
Post by marzz » Wed Dec 25, 2013 12:28 pm
chunky79 wrote:Amazing build.
cheers,
marzz
Post by marzz » Fri Jan 03, 2014 1:23 pm
just knocked the LED swap today ..
couple of phone pics after swap, will take some nice ones later...
marzz
Post by marzz » Fri Jan 03, 2014 1:43 pm
Also, received the mid section from Kline to complete the whole system and mellow the sound a little ...
marzz
Post by marzz » Sun Jan 05, 2014 1:32 pm
knocked the apikol rear diff mount upgrade out of the way yesterday ...
marzz
Post by marzz » Wed Jan 08, 2014 12:21 am
think I'm done with the exhaust, unless something brakes, the initial sound in combination with the SC wine is just awesome , best I've had so far, mind due the Kline setup is bigger in diameter 2.75" vs 2.5" stock, clips to follow when sound settles in ...
marzz
Post by marzz » Wed Jan 15, 2014 4:32 am
in for check up recently ...
hlbeckley
Post by hlbeckley » Wed Jan 15, 2014 12:26 pm
Absolutely beautiful
How you enjoying the charger? Box holding up?
When do you hit your first track day?
marzz
Post by marzz » Thu Jan 16, 2014 9:08 am
hlbeckley wrote:Absolutely beautiful
cheers, SC is just awesome, launch control at 3000RPM and over lights up all tires, no impact on box, such a fun to drive now, the response from the throttle is phenomenal, track session hopefully next month, been bit busy recently ... can't wait tho
marzz
Post by marzz » Fri Jan 17, 2014 6:56 am
ok, that's the chart before/after from City Performance, did not whitness the run so no video but will run again soon on dyno I previously used ...
how do you like the torque jump?
S4Player
Post by S4Player » Fri Jan 17, 2014 11:28 am
There's more room in that for sure, did you peg the torque to protect the box marzz? Has no one came out with clutch packs yet?
sakimano
Post by sakimano » Sat Jan 18, 2014 4:09 am
So about 480 WHP and 430 WTQ (ft lbs)
Will be interesting to see what it does at the strip. Hopefully you can get a cold day.
marzz
Post by marzz » Sat Jan 18, 2014 2:19 pm
S4Player wrote:There's more room in that for sure, did you peg the torque to protect the box marzz? Has no one came out with clutch packs yet?
there is always a room, just change the pulley/belt and increase boost, if you want to push it, I'm happy for now with what we achieved so far ...
running custom TCU software from German Motoring, as per Audi clutch packs can take up to 600Nm of input torque, considering that they over engineer everything so we are still of safe side, I think, guess we'll find out soon ...
Return to “Readers' Rides”
