ive been wanting to do a brake upgrade for a while and when the fronts done ill start on the rear,
i was kindly given some disks from Brett a member on here who went out of his way and met me early one morning, would have loved to had a chat and look more at his motor but didnt have time, there were the most sexyest set of ceramic brakes i have seen.
so they were in need of a skim and tlc but the size of these things is awesome RS6 390mm
i had my friend skim them up, they didnt need much, he took off 0.5mm, i still need to clean up the bells a bit but not going crazy as ive not even fitted them yet.
will keep you updated on these,
next was the oil and water cap, i know everyone is doing the R8 one but i dont like those really, i think its the yelow on the caps, so i bought the ones for the porsche 911, i knew these wouldnt fit from the start but knew they wernt far off. the coolant fitted fine but the oil needed some fettling, i used the lower part of the standard cap and the top part of the new one, dremmel and epexy later and voilla.
also fitted the revolution carbon intake which sounds sexy and looks the nuts, but makes my other buts look yellow.
finally ive sent a few bits to the guys at Argon, mainly interior bits but a couple of new exterior bits, will show you more when i get them.
