RS6 C5 Gearbox issues - Help!
sheffielder
Post by sheffielder » Thu Dec 05, 2013 5:52 pm
I'm new to the forum, but have had my beloved C5 for 5 years.
It's done just over 100000 miles and has recently developed the dreaded gearbox problems. My symptoms are the car disengaging during acceleration, revs shoot up, then an awful clunk into gear. Its worse once its warmed up, and under more load (uphill, strong acceleration) Its worst 3rd to 4th, but also seems confused 1st to 2nd and back to 1st in slow traffic - the clunk is there but just not as marked as the speed is so slow. 2nd to 3rd and 4th to 5th are still perfect.
TBH, symptoms have been there for a bit of time. It clunked just once a number of months ago, then no more problems for a while. Then did it again and eventually started doing it more often. However, its not doing it all the time and I have learnt how to drive it carefully to minimise the symptoms. Strange thing is its actually got better recently, but I only drive it for 10-15 minutes at once and only very carefully, and I know if I put my foot down, it will jolt into gear again, which tends to bring on the symptoms for another week or so. I don't understand why it's inconsistent and not problematic all the time, or why its got better, and wonder if its more likely an electronic than manual problem.
Obviously the time has come to bite the bullet and get it fixed. I want to sell it once its done, but i want to be able to say to a buyre its genuinely fixed. I've read a lot of the posts already on here about it, and have seen there's various problems it could be, eg just ATF fluid or pipe, or more serious things like torque converter, EGT or Oxygen sensors, valve body. I don't want to pay a fortune to get it fixed if it turns out its just a fluid issue (there is a small oil leak but I can't identify exactly where it is coming from, and come to think of it there was a similar small leak a number of months ago which seemed to clear up without a defintie fix, so i don't know if that may be linked). However, if it needs the full works, I want to get it sorted.
It sounds like Grizz at Unit 20 is top of the list to go to, but any advice, recommendations welcome.
amanda1
Re: RS6 C5 Gearbox issues - Help!
Post by amanda1 » Thu Dec 05, 2013 7:49 pm
I have bitten the bullet and had my gearbox fully strengthened by Trans 517 in America ..... Not cheap but mine is a keeper :bigblink:
Link here
http://www.517trans.com/catalog/11a.php
950 nm torque!
Post by chunky79 » Thu Dec 05, 2013 8:24 pm
Either go to Unit20, MRC or put it up for sale saying it needs a new box. That way the new owner can decide what to do. 517 is really only needed for modded cars.
Oh, and FON.
RustyBucket
Post by RustyBucket » Thu Dec 05, 2013 8:59 pm
Some people on here have had a result from having the fluid and filters changed and in addition to MRC and Unit 20 there was also a guy on here who used AMD in Essex http://www.amdtuning.com/product.detail ... eID=167585 and was delighted with the result. Where are you based?
Keaney
Post by Keaney » Fri Dec 06, 2013 12:57 am
Yip, take to MRC or unit20 for a gearbox service. Might fix it, otherwise they might be able to tell you if the clutch packs have went... You will however still need to pay for the filters and service etc etc
Worse case scenario gearbox refurb 5k+
Best case gearbox service £300ish
Good luck, depends if it's a keeper to go through the pain. Personally I'd sell it before getting it done if you were going to but it would need to be at a reduced rate
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
sheffielder
Post by sheffielder » Fri Dec 06, 2013 11:05 am
Cheers for all input. Rustybucket, I'm in Northampton area.
Would a gearbox service identify for example a cracked ATF pipe? If so, I think I'll sort out where the current leak is from and try a service first.
Is it really possible that the serious clunk gearghanges (and slight delay before gear engages at slow speeds) could be down to a cracked pipe and leakage of ATF?
Nobby
Post by Nobby » Fri Dec 06, 2013 11:44 am
To check the level the car needs to be brought upto temperature and the fill plug removed. If a tiny bit leaks out then the level is ok.
When the ATF is serviced the oil will be drained which will remove possibly half of the oil - there will be some left in the remaining passages of the gearbox and torque converter which is harder to drain. MRC might have tools to do this fully though. Remove the sump pan and replace the filter (which will show the tube which can crack) and check for any swarf inside the pan indicating wear to parts such as the clutch packs or casing etc.
General ATF colour and smell should indicate whether it is burnt or not too - it probably won't come out crystal clear anyway. Similarly if its black, thick and sludgey then its not good news.
An ATF leak shouldn't really happen from that many different places. There is obviously the sump gasket, the sump plug and drain hole (would be fairly obvious is the leak was from there), the feeds lines to the cooler and the cooler itself. All other leaks would likely be engine oil or DIFF oil such as rear output seal and driveshaft seals.
Daytona RS6 Avant
sheffielder
Post by sheffielder » Fri Dec 06, 2013 12:07 pm
Mmm
There has been a real burning smell just in the last few days after a short (10 minute) drive. I wasn't sure whether it was the leaked oil as its heated up or linked to gearbox problem!
ahoooga
Post by ahoooga » Fri Dec 06, 2013 1:19 pm
Don't mess around, any element of doubt suggests you should get onto MRC at Banbury and get their expert opinion.
Edited due to originally replying on a phone
RustyBucket
Post by RustyBucket » Fri Dec 06, 2013 10:03 pm
A quick blast down the A43 to MRC is your best bet and the chaps there to have a look
jimes256
Post by jimes256 » Thu Dec 12, 2013 3:42 pm
mine was leaking as i think someone had reused gasket on sump. also found they had not used an o ring between strainer and gearbox! new oil, o ring, strainer and gasket and all is fine. theres a guy in bristol who is mustard on these gearboxes and will fix with maximum bill of under 2k depending on the fault. Alex 07791493915
bilko1
Post by bilko1 » Sat Dec 14, 2013 11:49 pm
sheffielder wrote:Mmm
When my rear output shaft seal was leaking I got the burning smell but that is not ATF fluid. Also if your cam cover gaskets are leaking this normally drops on to the exhaust manifold giving a lovely burning smell to.
Weiß-sechs
Post by Weiß-sechs » Sat Dec 14, 2013 11:59 pm
I personally love the smell of burning Quantum 5W30
mavada
Post by mavada » Sun Dec 15, 2013 9:50 am
mine smells to, but only after giving it the beans...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by Shoppinit » Sun Dec 15, 2013 11:49 am
Are you talking about your car or your ass?
Users browsing this forum: No registered users and 245 guests
