In fact if you've got a VCDS cable, i can do a fair bit here. If not, you could order one for a few bucks....
chunky79 wrote:So he says, bet it was the other way round.Nobby wrote:Was that the one that kept coming onto you?Amar wrote:I work with two, one used to always ask for a lift home although she lived nowhere near me
Had this problem with mine.Shoppinit wrote:No, doesn't rob the car of power. Only comes on when the engine is warming up. The only reason to delete it is if it has failed and you don't want to cough up for a new one since it's only for emissions.
Problem is, if you don't delete it properly (blanking off plates and mapped out) then you will have the check engine light on the dash which could be hiding other faults. At worst you will be letting unmetered air in.
Sounds like that "spurt" needs a spurt from a high pressure hose up hisAggro65 wrote:Yeah, resistor? Read my earlier posts. Didn't work for me but as you've seen I had mega problems. From experience, if a make do fix is used, something is wrong. My sai is disconnected but the vacuum cleaner is still there. You can't take the pump out without the warning light. Maybe try and connect the plug and see what happens. The loud air blowing last for less than a minute when you cold start and you don't have the aggro of the warning light. I think it's worth a try especially knowing the bull I was fed by "spurts"
I used the alientech powergate that rich from viper recommended. You code it via the alientech website selecting your car. You then plug it into the obd, follow the instructions and it copies the map. I had a revo map done years ago and they locked the ecu and I couldn't get a copy of the map. I couriered my ecu and TCU to Rich in Douglas(from johannesburg) Money well spent.Mr Footlong wrote:Bloody hell, sounds like some testicle-tazering is in order for that chap! Well played sorting as much as you did yourself. How is this remote ECU mapping done exactly guys? Obviously I don't need it but I am curious.
