VCDS Error code
Yanos
Re: VCDS Error code
Post by Yanos » Sun Nov 10, 2013 9:03 pm
Charliesheen wrote:Hi fellas,
I've been getting the same fault code and intermittent Epc and emissions light on the dash but I also have what feels like the rev limiter cutting in at 6000 rpm.
Car drives fine with no limp home mode and if I steadily build revs it will continue on to 8000rpm but most of the time it splutters at 6000rpm and cuts power..
Driving me nuts
Sounds like you have a similar problem to what I had. I was getting a power cut around 5.5k
One of the flaps had loads of play in it and thats what was causing the intermittent light and confusing it. Your not going to know until the manifold is off thought so its do or die time! I went for the de flap instead of new manifold and its made a huge difference. Now I get full power all the way through the rev range.
Saying that it could also be a vacuum leak. There are a few tests on here you can try out, searching should find them :thumbs:
RS4 B7 Misano Red Saloon / Black Optics / Revolution - Pipercross Carbon air intake / Carbon Clean / Black Rings / Lepsons Black Chrome Alloys
GAZ-MAN
Re: VCDS Error code
Post by GAZ-MAN » Fri Nov 29, 2013 11:21 am
Driving me nuts
deflap? whats involved here mate? my epc light seems to come on just in the morning when cold and goes off after few miles of driving and wont come back on till the next morning, im going to get a terraclean done next week i noticed on the exhausts the vac pipes have been cut and plugged so the flaps are open all the time
Yanos
Re: VCDS Error code
Post by Yanos » Sun Dec 01, 2013 11:57 am
Driving me nuts
This sounds similar again mate, mine did that.
The deflap is basically manifold off then tumbler and manifold flaps removed, there are choices as to whether to remove the rod or not. I left mine in so I didnt have to map it out. I am however planning a map in the coming months.
Users browsing this forum: Google [Bot], Google Adsense [Bot], N9ATH and 77 guests
