My Rs4 Project
Gavla
Re: My Rs4 Project
Post by Gavla » Wed Jul 03, 2013 11:22 pm
Yeah I went for the same 6% I think - they say it needs a few weeks to cure. Did you get much cloudiness or trapped moisture?
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
Rick_RS4
Re: My Rs4 Project
Post by Rick_RS4 » Wed Jul 03, 2013 11:40 pm
Gavla wrote:Yeah I went for the same 6% I think - they say it needs a few weeks to cure. Did you get much cloudiness or trapped moisture?
it was a bit cloudy to start with but went the next day, i used a squeegee and a hair dryer worked a treat, messed it up the first time i did it but wasnt much dollar,
Re: My Rs4 Project
Post by MikeFish » Wed Jul 03, 2013 11:45 pm
Rick_RS4 wrote:cheers, yeah its light smoke lamin x,
re the exhaust it will have to wait as my exhaust guy is booked up until atleast august :( but i have collected some parts ready, really cant wait to get it done,
Looking good Rick!!!
What parts you collected?
Rick_RS4
Re: My Rs4 Project
Post by Rick_RS4 » Thu Nov 07, 2013 3:12 pm
so today these turned up
ready to go onto the new wheels tomorrow,
dont get too excited they have been done before so nothing new in affraid.
Re: My Rs4 Project
Post by MikeFish » Thu Nov 07, 2013 3:23 pm
Can't wait to see them on rick. Will look a bit different as you have the right size tyres so will look lower profile.
Rick_RS4
Re: My Rs4 Project
Post by Rick_RS4 » Thu Nov 07, 2013 4:24 pm
Thanks Mike, just thought do I need spigot rings? And I need to find my original wheel bolts, because I have spacers on mine, unless your running spacers?
Re: My Rs4 Project
Post by MikeFish » Thu Nov 07, 2013 6:34 pm
I had rubbing with spacers but it turned out later my shocks were duff so that didn't help.
Depends how low it's sitting I guess, there is no room between the rear wheel arch and my tyre but that is with 265/30 which are wider and higher than your tyres so you might be able to get away with it.
I would drive with the spacers, but would rub a lot. Might be worth me trying again now the suspension is sorted though.
And yes you will need spigots. I got the both the metal and plastic ones and ended up using the plastic ones.
Rick_RS4
Re: My Rs4 Project
Post by Rick_RS4 » Thu Nov 07, 2013 11:39 pm
MikeFish wrote:I had rubbing with spacers but it turned out later my shocks were duff so that didn't help.
great ill try them on tomorrow and see how it goes, 255 30 20 are the same rolling radius as the 25535 19s so should be ok hopefully, balls hope i can get some spigots local tomorrow do you know what centre bore i need.?
Re: My Rs4 Project
Post by MikeFish » Fri Nov 08, 2013 12:46 am
Yes 255/30/20 is identical to 255/35/19. 265/30/20s are a bit higher though.
The B7 has a centre bore of 57.1 and the RS5 / B8 has a centre bore of 66.6
This is the type of thing you want:
http://www.ebay.co.uk/itm/4x-66-6-57-1- ... 174wt_1302
Where about in the country are you Rick? I think I have a set in the garage.
PetrolDave
Re: My Rs4 Project
Post by PetrolDave » Fri Nov 08, 2013 7:29 pm
Rick_RS4 wrote:255 30 20 are the same rolling radius as the 25535 19s
No they're not - the sidewall height of the tyre is the same (255*35/100) but as the wheel diameter is 1" (25.4mm greater) the rolling radius will be 12.7mm greater.
Try typing the numbers into any of the many online tyre size calculators such as http://www.etyres.co.uk/tyre-size-calculator
Re: My Rs4 Project
Post by MikeFish » Fri Nov 08, 2013 7:32 pm
Dave I've done this calculation loads of times and it has always come up the same.
Re: My Rs4 Project
Post by MikeFish » Fri Nov 08, 2013 7:37 pm
Just done it again and still the same. Are you sure you changed the profile size and diameter when you did the calcs? In my experience if you keep the width the same and go up an inch in wheel size then a drop in profile (by one size) will give you an identical rolling radius so 255/35/19 must be the same as 255/30/20.
PetrolDave
Re: My Rs4 Project
Post by PetrolDave » Fri Nov 08, 2013 7:40 pm
MikeFish wrote:Just done it again and still the same. Are you sure you changed the profile size and diameter when you did the calcs?
My bad - I left the profile at 35 :bowdown:
Rick_RS4
Re: My Rs4 Project
Post by Rick_RS4 » Fri Nov 08, 2013 8:20 pm
so wheels went on today, no pics yet, i ordered new valves but they were the wrong ones so will get them changed, also get some scrubbing with the wheel spacers on so they are now forsale, and centre caps are wrong size,
however
they look the tits
Re: My Rs4 Project
Post by MikeFish » Fri Nov 08, 2013 8:34 pm
Good work fella but come on Rick, get some pics up!
Users browsing this forum: Google Adsense [Bot] and 62 guests
