Non heating lambda sensor
Revolvo
Post by Revolvo » Thu Nov 07, 2013 7:45 pm
So the engine light comes on because the ECU is failing to tell the lambda sensor to heat.
No results for that found on search function. Anyone ever encounter that before?
Specialist says new ECU needed, or existing one examined/reflashed etc?
Help.....
2002 Mugello blue RS6, silver interior. FASH.
Goblin-eater under the bonnet.
81 Mini 850 > 87 Mini Cooper > 68 Volvo Amazon > 81 Golf GTi > 90 Corrado G60 > 89 320i > 02 Blue Thunder.
bilko1
Re: Non heating lambda sensor
Post by bilko1 » Thu Nov 07, 2013 8:05 pm
What is the fault code? It's quite common for the heater circuit to fail in O2 sensors. I doubt it's the ecu, you need a wiring diagram for the O2 sensor circuit then check all wiring and fuses / relays on that circuit.
Revolvo
Post by Revolvo » Thu Nov 07, 2013 8:13 pm
It's saying that the z19 heating element is not drawing a current. Brilliant.
Gripper1
Post by Gripper1 » Thu Nov 07, 2013 8:46 pm
It wouldn't draw a current if it's not working
Revolvo
Post by Revolvo » Thu Nov 07, 2013 9:35 pm
Gripper1 wrote:It wouldn't draw a current if it's not working
Yes, so it looks, unfortunately, like I'll have to have somebody look very carefully at my ECU. To see what's happened, how to repair. Only fails from cold start, 600 C and I'm laughing but means driving everywhere with VAG COM to reset engine light every time I start-up.
Gripper1
Post by Gripper1 » Thu Nov 07, 2013 10:19 pm
No sorry you haven't quite got what I meant by it.
If the heating part of the lambda circuit is open circuit (ie a break in a wire/internal fault on the lambda) you will get no current draw. The ECU is looking for a certain current draw from the sensor on startup and if it doesn't see it, it throws the CEL
The ECU I'm sure will be absolutely fine. You just need a new Lambda.
If you can give the exact code it will help considerably.
Nobby
Post by Nobby » Thu Nov 07, 2013 11:44 pm
Switch the plugs to the other sides. If the problem moves then it confirms the lambda is faulty. If it stays the same side then could also be wiring
Daytona RS6 Avant
Post by chunky79 » Fri Nov 08, 2013 7:51 am
Nobby wrote:Switch the plugs to the other sides. If the problem moves then it confirms the lambda is faulty. If it stays the same side then could also be wiring
This would be the easiest thing to do, the plugs are pretty easy to get to too.
Edit, why have you started another thread when you already have one running :?:
Revolvo
Post by Revolvo » Fri Nov 08, 2013 8:24 am
Thanks guys, tried switching connectors but problem still exists. Probably means that I didn't actually need the new lambdas that were recently fitted.
New thread because i had and "oh no" moment.....
Post by chunky79 » Fri Nov 08, 2013 11:48 am
Sounds like you have a bad connection somewhere. It's making a good connection when warm.
Revolvo
Post by Revolvo » Fri Nov 08, 2013 1:44 pm
Yeah, car going like a bullet, no misfires, no lean running etc. everything good except for that engine light..... Because ECU is not sending current on Z19 lambda sensor heating circuit on start up.
Nobby
Post by Nobby » Fri Nov 08, 2013 2:56 pm
Try to find the pinout for the lambda sensor at the ECU and check the line for integrity. If your lucky the loom will be in a few sections and you could replace a little bit of it.
I don't think it would be the ECU itself. ECU's generally either work 100% or go completely balls up.
Daytona RS6 Avant
Post by Shoppinit » Sat Nov 09, 2013 10:50 am
Revolvo wrote:Thanks guys, tried switching connectors but problem still exists. Probably means that I didn't actually need the new lambdas that were recently fitted.
Still exists at same bank / sensor?
You sure you're not mixing up the pre- and post cat-sensors?
Also, post your fault codes.
Users browsing this forum: Bing [Bot] and 210 guests
