Rolling Road Day @ AmD Essex
Scaff657
Re: Rolling Road Day @ AmD Essex
Post by Scaff657 » Mon Oct 21, 2013 10:26 pm
S4WON wrote:
Scaff657 wrote:Well said jay this is all very true I had stage 1 manifold stage 2 remap and de coke
Well over a year ago at Mrc and my read out was 429 ps
A year or so on and only done 4k miles in that time now it's 406ps that is crazy
I'll never understand stupid bloody cars :biggrin3:
scaff have you filled up with the same petrol, literally every tank?
Yes I been using the v power everytime as this is what Doug recomended :bigblink:
At 200mph you have no friends
Firestarter
Post by Firestarter » Mon Oct 21, 2013 10:28 pm
scaghead wrote:
PetrolDave wrote:
C17LJR wrote:What's going on with the cars Louie and Saf?
My money is on there being a vacuum leak somewhere on both cars. More often than not that's the cause of such low power output on the B7.
Plus 1... AMD think the same...
My MAF is (was) fcuked and that combined with huge heat soak through the revolution induction kit may be the issue. I had cleared the DTCs using VCDS after fitting the dry cone filter that came from Revolution and for the first 70 or so miles the car was flying, but Im told that the ECU re learns and as the MAF is the first point where air is detected, if this is in the slightest corrupt it will completely feck the car and it started to hesitate and feel laboured from 5 toi 8k....Bit like Mikes car....New MAF fitted and it was flying again.
So New MAF coming tomorrow and refitting the standard air box but with a Pipercross panel filter. Then back to AmD for fitting of a JHM short shifter and another dyno run....Hopefully it will be a lot better than 330bhp :dung: :dung: :dung:
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT :-)
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre :-)
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
RIV
Post by RIV » Mon Oct 21, 2013 10:32 pm
I'll give you a fiver for the airbox Louie, might retro fit it to my t5 :nodder:
Firestarter
Post by Firestarter » Mon Oct 21, 2013 10:34 pm
Silas wrote:I'll give you a fiver for the airbox Louie, might retro fit it to my t5 :nodder:
:biggrin3:
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
lengster1
Post by lengster1 » Mon Oct 21, 2013 10:37 pm
Anyone got graphs? be nice to compare the b8 delivery against a decent power b7.see how good my arse cheek Dyno is at the feeling of a severe lack of torque in the b8.
S4WON
Post by S4WON » Mon Oct 21, 2013 10:38 pm
Well, that's my theory out the window then!!
scaghead
Post by scaghead » Mon Oct 21, 2013 10:39 pm
Louie why the standard airbox,now you have the dry filter for the revolution kit?
saintS400
Location: Tremenheere Farmhouse, Trewennack, Helston, Cornwall TR13 0PW
Post by saintS400 » Mon Oct 21, 2013 10:57 pm
Thanks Louie. Yesterday was really enjoyable & good to meet up with everyone again. Also good to meet some new faces. Name tags were a great idea.
Nice to see my car was running around what it should be on your Dyno.
A great turn out of some great looking & sounding cars. I may be a little more deaf than I was on Saturday but it was worth it. :thumbs:
S4 B8 MRC stage 2 map, MRC custom supercharger pulley & high grip belt, MRC high flow air filter & silicone intake pipe, MRC cooling upgrade, Bilstein PSS9's, RS5 Brake upgrade, H&R ARB's, MRC gearbox re map, Supersprint cat back exhaust, Michelin Pilot Supersport tyres. 500.7ps 596nm. Now sold sadly.
Firestarter
Post by Firestarter » Mon Oct 21, 2013 11:01 pm
scaghead wrote:Louie why the standard airbox,now you have the dry filter for the revolution kit?
Well this is where things get a little "grey"
AFAIK the other chaps with the MAF issue caused by the wet filter have, after fitting the dry filter not had issues. However both Ben and the tech (not sure of his name) that was doing the wheel alignments and also fixing a few cars said that the DTC fault im getting........
08567 - Bank 1; System Too Lean off Idle P2177
could be as a direct result of the induction kit combined with heat soak (and of course the fecked MAF) so Im a tad confused but not letting it piss me off (yet) :bigblink:
OK so what I will do first thing tomorrow is this
1, Replace MAF
2, Clear DTCs
3, Retain Revolution induction kit and run the car to see if the fault re appears
Ross-Tech Wiki states
http://wiki.ross-tech.com/wiki/index.ph ... 177/008567 :bash: :bash:
Also had this the other day but its not re appeared since I cleared the DTCs
001169 - Secondary Air Injection System: Bank 1 P0491 - 002 - Insufficient Flow :bash:
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
sync24
Post by sync24 » Mon Oct 21, 2013 11:23 pm
True words mate - I had mine decoked, stage 2 tune with pipercross filter & catless bespoke twin 2 1/2" zorst - I gave 428 @ MRC, Sunday I got 404 - It's just not worth touching the engine more than a light fettle and an exhaust unless you are going SC'd - For me, that's the end of engine mods.
Ginors4
Post by Ginors4 » Mon Oct 21, 2013 11:33 pm
Think we should stick another fiver in for who lost the most power over the shortest amount of time. I'm currently at -44hp in three months.
Gone and miss very much
B7 RS4 Avant Misano Red, lepsons 2-tone black shadow chrome rims, KW coilovers, AMD Stage-1 with valved non-res milltek catback.
Ginors4
Post by Ginors4 » Mon Oct 21, 2013 11:34 pm
Think we should stick another fiver in for who lost the most power over the shortest amount of time. I'm currently at -44hp in three months. :boohoo:
Graeme4130
Post by Graeme4130 » Mon Oct 21, 2013 11:36 pm
lengster1 wrote:Anyone got graphs? be nice to compare the b8 delivery against a decent power b7.see how good my arse cheek Dyno is at the feeling of a severe lack of torque in the b8.
Hi mate
Hopefully this is legible
Firestarter
Post by Firestarter » Mon Oct 21, 2013 11:39 pm
Ginors4 wrote:Think we should stick another fiver in for who lost the most power over the shortest amount of time. I'm currently at -44hp in three months. :boohoo:
55bhp since 2/9...standard 385 tuned 330...<beep> bollocks that!!! :dung: :dung: :dung: :piss: :piss: :piss:
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Ginors4
Post by Ginors4 » Mon Oct 21, 2013 11:43 pm
Best stick ya fiver in them fella :bigblink:
I'm sure it will get sorted very soon
Users browsing this forum: Google Adsense [Bot] and 186 guests
