10mm spacers on front
Dos anyone run 10mm H&R spacers on the fronts? Need to know if they make the steering judder at all? Cheers
RS4 B7 Saloon
Phantom Black
Black optics
Non-res milltek - non valved - gutted pre cats
LED interior lighting
LED's all round - xenon DRL's
19" standard alloys in graphite grey
H&R springs
H&R spacers
Phantom Black
Black optics
H&R springs
H&R spacers
Re: 10mm spacers on front
Firestarter had a topic just a week or so ago, sure a few members have 10mm on the front.
Regardless of size of spacer though, it won't cause wheel wobble
2007 Daytona Grey RS 4 Avant
2013 Daytona Grey RS 4 Avant
If the spacers are hub-centric then you'll be okay
10mm though will be a bit tight with std wheels, taking a looking at your signature you appeared to have lowered the car already, I went for 8mm on the front and I still had some slight rubbing whilst under heavy load. Running 65cm front & 64cm at the back. (taken from wheel arch)
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
Well basically I was gonna have it done yesterday hence why I put it on my signature but when I went to collect they said the 10mm hub centric spacers didn't sit completely flush with the wheel which could cause steering wobble! So they suggested to make up to spigets of solid metal to sit in the middle so they could sit flush as they have done this for many rs4's due to the lip being too big on the hub centric spacers!
RS4 B7 Saloon
Phantom Black
Black optics
H&R springs
H&R spacers
Phantom Black
Black optics
H&R springs
H&R spacers
That's the first I heard of this with these spacers!?
(Although I had 8mm at the front)
I would PM Virdee on here as he has a lot of experience in this area.
This ^^^^^
I keep hearing of people with trouble with spacers except for those that use Virdee. You don't need spigots if you have the right hubcentric spacers. There are lots of different tyoes with different lip sizes, angles etc but Virdee know the ones that work on our cars.
Cheers for the help! Pm'd virdee now so just waiting for a reply! May ring Unit 20 tomorrow too!
RS4 B7 Saloon
Phantom Black
Black optics
H&R springs
H&R spacers
Phantom Black
Black optics
H&R springs
H&R spacers
- Firestarter
try these
http://www.ebay.co.uk/itm/300504108276? ... 1439.l2649
I had to raise the car a tad as together with these I have 15mm spacers on the rear and originally had slight rubbing. No wobble issues and they are a quality bit of kit and come with the extended wheel bolts as well. link to 15mm below
http://www.ebay.co.uk/itm/290511867821? ... 1439.l2649
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
- MartayMcFly
- 5th Gear
That just sounds like you're using the wrong spacers. I've heard of some with too shallow a chamfer on the inside edge that fouls on internal radius on the hub, so doesn't sit flush. It happens with some rep wheels too (when using spacers), I think.Cal.rs4 wrote:Well basically I was gonna have it done yesterday hence why I put it on my signature but when I went to collect they said the 10mm hub centric spacers didn't sit completely flush with the wheel which could cause steering wobble! So they suggested to make up to spigets of solid metal to sit in the middle so they could sit flush as they have done this for many rs4's due to the lip being too big on the hub centric spacers!
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
Please do share the outcome of your converstaion with Virdee on the type and make of spacer he recommends. I am also interested thanks
- Surrey Sam
There are quite a few different bevel angles made by H&R for the Audi 5 hole PCD, it sounds like you have the wrong one and the spacer is not sitting flush to the hub face.
There was along discussion on the different types on here, and it seemed the only way to get the right ones was to go to Virdee or like somebody else mentioned, Revolution.Jaykz wrote:Please do share the outcome of your converstaion with Virdee on the type and make of spacer he recommends. I am also interested thanks
+1MartayMcFly wrote:That just sounds like you're using the wrong spacers. I've heard of some with too shallow a chamfer on the inside edge that fouls on internal radius on the hub, so doesn't sit flush. It happens with some rep wheels too (when using spacers), I think.Cal.rs4 wrote:Well basically I was gonna have it done yesterday hence why I put it on my signature but when I went to collect they said the 10mm hub centric spacers didn't sit completely flush with the wheel which could cause steering wobble! So they suggested to make up to spigets of solid metal to sit in the middle so they could sit flush as they have done this for many rs4's due to the lip being too big on the hub centric spacers!
What's the part number on the box and spacer?
Check this old thread: http://forum.rs246.com/viewtopic.php?f= ... hilit=10mm
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
Thanks for all your help! Sorted it with APS now after ringing unit 20! No part number as they still have my spacers but they are the right ones!
RS4 B7 Saloon
Phantom Black
Black optics
H&R springs
H&R spacers
Phantom Black
Black optics
H&R springs
H&R spacers
10 mm is too much on the front IMO,looks chav from the front and leaves the wheels protruding the arch too much,I've also a set of 10mm hubcentrics that didn't seat properly,they were off eBay but never arsed to return em.Bought the cheapies for my a4 tdi,RS has H&R,I run 3mm plain on the front of RS and 10 rear it's just right,5mm plain on the front is dangerous though as the wheel doesn't locate on the hub centre any more.
Users browsing this forum: No registered users and 129 guests
