Audi RS4 Test Drive
sk1808
Audi RS4 Test Drive
Post by sk1808 » Wed Oct 16, 2013 5:18 am
The rs4 saloon I drove has 55k on the clock and is built 2007 being sold by a private dealer
The first shift I did into 1st refused to go into gear. The salesman just said let go of the clutch and try again
So I tried again and didn't go again. He then said your pushing the gear to far over and just needs a little bit. When I did this (only moved gearstick a bit over and up for first) it went in gear no problem.
On getting the car checked I was warned also about "knocking" from the gearbox
Is this anything to be concerned about
1 person told me to stay away the gearbox is on its way out but maybe I'm looking to much into it
Any thoughts?
S
Ps: as I put down my deposit, the dealer told me last buyer of the car was put off the car from the gearbox decide not to buy it and lost his deposit.
Dec369
Re: Audi RS4 Test Drive
Post by Dec369 » Wed Oct 16, 2013 6:26 am
Tell them you want a full warrenty with the car, just to replace a full clutch (flywheel ect) your looking at £1500 +
S4WON
Post by S4WON » Wed Oct 16, 2013 7:21 am
Run Forrest run
Hate to be harsh but unless this is your first car or you've never used a manual gear box this is NOT normal behaviour.
This ain't gonna end well... Sorry!
John Johnson
Post by John Johnson » Wed Oct 16, 2013 7:37 am
Gear change is normally quite good , I'd move on from that one
Current toys in the garage
Ur quattro. lago Blue
Ur quattro. Mars red
Rs1600i
Transit custom sportvan
http://youtu.be/FWBUl7oT9sA
pDkALO
Post by pDkALO » Wed Oct 16, 2013 11:02 am
agree with other responses - move swiftly on. they do NOT all do that
PetrolDave
Post by PetrolDave » Wed Oct 16, 2013 5:53 pm
DALO wrote:agree with other responses - move swiftly on. they do NOT all do that
+3
Lukes3
Post by Lukes3 » Wed Oct 16, 2013 5:54 pm
I also have this problem with mine now an then only with 1st, an i have heard an read that it could be down to a faulty engine mount.
Had the car pluged in at my local audi/vw specialist and a engine mount fault poped up. Not had it changed yet tho so cant say what or how to fix as yet.
coffey555
Post by coffey555 » Wed Oct 16, 2013 7:02 pm
I had an active engine mount replaced last year as it was throwing up error codes. The car was slightly easier to drive at low speed afterwards but in my case, it made zero difference to the gear change quality.
Misano Red RS4 B7 Avant
TonyHayers
Post by TonyHayers » Fri Oct 18, 2013 11:14 am
Needs new clutch.
06 Phantom Black Saloon:
^ GONE :cry:
spikeyboy101
Post by spikeyboy101 » Fri Oct 18, 2013 2:02 pm
i would also walk away - could be big bills in the future.
As for losing your deposit, were you made away at time of putting it down that it was non refundable ? also was the issue with the gearbox declosed, onbasis the dealer clearly knew about it as they had already lost one customer from it.
Users browsing this forum: Bing [Bot] and 99 guests
