Sticky for pics/vids RS6 C5
Mr V10
Post by Mr V10 » Tue Oct 15, 2013 1:11 pm
bam_bam wrote:There's a lot to be said about gloss optics. I'm pretty sure Amar's C6 has them, it was a custom job from an Audi paintshop, IIRC.
Unless it's something done by Tony/DK, I thought it was just from factory.
Post by bam_bam » Tue Oct 15, 2013 4:25 pm
I'm not sure it was factory as it wasn't an ordering option from the outset, AFAIK. It was probably a special order, not a cheap one as DK said. Maybe you could clarify with him, I'd prefer to just vaguely 'remember'. Either way, gloss optics are interesting.
Post by HYFR » Tue Oct 15, 2013 4:43 pm
^^ it was / is gloss black on LOON.
Audi Exclusive option.
Mr V10
Post by Mr V10 » Tue Oct 15, 2013 4:55 pm
It was ordered through Audi exclusive according to Audi's system when they put my VIN in, so maybe...
-[PQE] Audi Exclusive black styling package
Post by bam_bam » Tue Oct 15, 2013 5:21 pm
So there you go, an Audi exclusive option - would this be done in the factory or after? Exclusive don't sound cheap, how much was it?!
Mr V10
Post by Mr V10 » Tue Oct 15, 2013 5:31 pm
Factory, dealer fitted options wouldn't be shown on the system recorded through the VIN. Not sure on cost, but it was £93k vs £76k list... I do really like the glossy finish. :kissmyrings:
mavada
Post by mavada » Thu Oct 17, 2013 9:08 am
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by bam_bam » Thu Oct 17, 2013 4:23 pm
Some of you may know this car, it's called Judas.
It started out life as a broken stock RS6, the owner then shoehorned an LS1 into it. Then, he took leave of his senses, stroked it to 383, built the internals and mounted two Chinese turbos remotely, just before the tailpipes. It's since caught on fire with no other updates I can find (I haven't be bothered to look).
http://www.theprojectpad.com/viewtopic.php?f=24&t=12
Post by chunky79 » Thu Oct 17, 2013 7:20 pm
Think I saw something on rs6.com about this car. It set fire outside a grocery store :thumbsdown: . Mega build!
mavada
Post by mavada » Fri Oct 18, 2013 8:16 am
Yellow Koni's
mavada
Post by mavada » Tue Oct 22, 2013 9:39 pm
Yellow Koni's
RIV
Post by RIV » Tue Oct 22, 2013 9:51 pm
Spotted this at MRC last week, apparently owned by someone on the forum, bit of a trouble maker so I've been told :bigblink:
bilko1
Post by bilko1 » Tue Oct 22, 2013 11:50 pm
WHAT HAVE YOU BROKEN NOW BAM?
Post by Shoppinit » Wed Oct 23, 2013 8:04 am
is that a Lebanese Audi next to it? :shock:
Post by bam_bam » Wed Oct 23, 2013 11:43 am
ATF temp sender so the TC wouldn't lock. So, I sent the VB off to 517trans and they rebuilt it. MRC replaced the VB loom and also found the engine oil overfilled by AmD. They also rectified a leak to the turbos with engine in situ which AmD wanted to perform an engine pull.
The car has been on the dyno without any gearbox slip and a test drive didn't find any slip either, so I'm very happy.
It'll be painful getting back into the 'loon, I'm sure a manual in the C5 is just wrong, it's great on track but everywhere else I'm sure the tiptro comes out on top.
