Ride height
Rick_RS4
Re: Ride height
Post by Rick_RS4 » Wed Oct 09, 2013 9:35 pm
those spacers are too wide imo,looks like a old school corsa modding, as Silas says maybe needs a jig or the subframe has been adjusted, i dont think the rear camber is adjustable
AdrianD
Re: Ride height
Post by AdrianD » Wed Oct 09, 2013 9:54 pm
Firestarter wrote:Ok cool, thanks Mike. Get this......I've just checked the ride height on a dead level surface as my garage floor is dead plumb bot length and width. Ride height on n/s is a mm under 67cm whereas on the o/s its at 66cm! Also having fitted the 15mm rear spacers the n/s is protruding more than the o/s......WTF??? I've goton on to Ben @ AmD and going to get the car in to them to check as something is definitely not right. Pics attached
Mine looks lower than that on standard SS+ suspension.... is that right or do i have a problem? Just had a service at Audi and it came back with no problems mentioned...
2010 911 Turbo PDK.
Gone but not forgotten... Sprint Blue B7 RS4 with all the toys :)
20" AG M310's | TTS Supercharged | MRC Stage 3 | Sach's Clutch | Lightened / balanced flywheel | High Pressure Fuel Pumps | KW V3's Coilovers | De-Cat + Valved Milltek | DeCoked | Launch Control | Flat Shift | Cold Air Feed Induction.
Surrey Sam
Re: Ride height
Post by Surrey Sam » Wed Oct 09, 2013 10:37 pm
Louie, did you take it out for a drive to settle out the suspension after jacking it up?
C17LJR
Re: Ride height
Post by C17LJR » Wed Oct 09, 2013 10:49 pm
It's obvious, there's just more hammerite on the wheels mounting surface on the near side than there is on the off
2007 Daytona Grey RS 4 Avant
2013 Daytona Grey RS 4 Avant
Steesh
Re: Ride height
Post by Steesh » Fri Oct 11, 2013 3:11 pm
Those who have 15 and 10 mm spacers fitted - standard wheels on?
I've just fitted KW adjustable springs - only went with the front to bring it in line with the rear on SS+ suspension - sits perfect IMO
I reckon i could go with the 15 & 10's (10 & 8's on just now) but that's because the wheels are 32 offset rather than 29 on the standards.
