Ride height
toyneg
Ride height
Post by toyneg » Tue Oct 08, 2013 10:48 am
Hi guys, had the K/W lowering springs fitted yesterday, car looks the nuts but it's scraping while turning with any 'fastish' speed and any bump of size rubs - it seems to be coming from the arch liner screw mainly. I had 64cm at the back and 65cm at the front, standard wheels and 8mm and 10mm spacers. I know this is what Gavla is running, is anyone else got similar, would welcome others feedback :-)
scaghead
Re: Ride height
Post by scaghead » Tue Oct 08, 2013 11:14 am
What size tyres are you running fella(275/255) as I would be surprised if your getting any issues with 255s..I am running 265s with kws and I get a slight rubbing when three in the back..
toyneg
Re: Ride height
Post by toyneg » Tue Oct 08, 2013 11:16 am
Just 255/35 19s mate, the back seems ok but the front seems to scrape on the arch lining screw? Have you got the same ride height?
toyneg
Re: Ride height
Post by toyneg » Tue Oct 08, 2013 11:18 am
Was gonna pop back to AMD this arvo as I'm quite near today at a customer meeting :-)
scaghead
Re: Ride height
Post by scaghead » Tue Oct 08, 2013 11:24 am
I am 65cm at the front as well but running 30s with 8 mm spacers...maybe worth getting it raised 5 mm as after a few months it will settle a bit..or see if they can do anything with the screw if that is all that is causing the issue?
toyneg
Re: Ride height
Post by toyneg » Tue Oct 08, 2013 11:32 am
Yeah I'll give that a go, thanks scaghead
C17LJR
Re: Ride height
Post by C17LJR » Tue Oct 08, 2013 12:15 pm
Removing the arch liner screw would be first on the list for me
2007 Daytona Grey RS 4 Avant
2013 Daytona Grey RS 4 Avant
Gavla
Re: Ride height
Post by Gavla » Tue Oct 08, 2013 1:17 pm
Hi Toyneg,
I had the arch liner screw removed as it will rub with it. In fact running H&R 8/10 with it lowered does accentuate the possibility of it rubbing - mainly though it only appeared for me on very rough road conditions. However I recently sold my spacers as my driveway has a steep incline and it started to rub every time when I went in at an angle. ;-(
I think Noyjatat runs 5mm shims at the front - thinking of putting them on as I do miss the look it gives.
Cheers,
Gav
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
toyneg
Re: Ride height
Post by toyneg » Tue Oct 08, 2013 1:33 pm
Cheers Gavla, I'm getting them to raise it 5mm and take out the screw, ill test how that feels. I didn't know you could get 5mm spacers, I'll ask Gaz about that
Gavla
Re: Ride height
Post by Gavla » Tue Oct 08, 2013 1:49 pm
Cool - it will make a difference. I believe 8mm is the lowest hubcentrics that H&R manufacture? Anything lower than this then I believe it has to be a shim. Unless anyone else knows of an alternative?
EDIT/>
http://www.performancealloys.com/alloy- ... D=12&tab=3
toyneg
Re: Ride height
Post by toyneg » Tue Oct 08, 2013 4:29 pm
scaghead wrote:I am 65cm at the front as well but running 30s with 8 mm spacers...maybe worth getting it raised 5 mm as after a few months it will settle a bit..or see if they can do anything with the screw if that is all that is causing the issue?
Went with that Scaghead and all sorted, no rubbing at all. Thanks to you and Gavla :-)
Gavla
Re: Ride height
Post by Gavla » Tue Oct 08, 2013 5:05 pm
nice one - glad it's sorted :thumbs:
Re: Ride height
Post by MikeFish » Tue Oct 08, 2013 5:30 pm
I'd have just removed the screw first. That could have solved your problem without having to raise the height. I'm surprised whoever fitted the springs didn't take it out for you. I forgot to mention it to unit20 but they did it anyway.
Re: Ride height
Post by MikeFish » Tue Oct 08, 2013 5:32 pm
And Graham, I'm surprised at you... you should know the rules by now, especially the first rule!
I took some more of mine at the weekend now that the front has settled a bit more. Just need to edit out my number plate then I'll post them up somewhere.
scaghead
Re: Ride height
Post by scaghead » Tue Oct 08, 2013 6:13 pm
Glad it's all sorted fella..the good thing is if your not happy with it,you know you have the scope to go lower..
Users browsing this forum: No registered users and 104 guests
