I went ahead and bought a nice 06 Avant in Daytona - Yay
One of particular note was "N145 Right Solenoid Engine Mount - Defective" - what is this, what does it do and what happens if I don't get it changed?? Quoted £394..
1. Rear Washerjet blocked.adsgreen wrote:.............What other things did they find?
Hi BombBomb_Doctor wrote:1. Rear Washerjet blocked.adsgreen wrote:.............What other things did they find?
2. Front x 2 and Rear x 1 wiper blades need replacing.
3. Thermostat housing O ring leaking, requires new O ring & housing bolts due to corrosion.
4. Lower lefthand oil cooler pipe to intercooler ‘slightly sweating’. All union pipes are corroded, might require all pipes and intercooler if pipe replaced.
5. Near side front suspension strut leaking.
6. Off side rear suspension strut leaking.
7. Front discs and pads (pads 80% worn) They say they can’t put just pads on… as the worn lip on the disks will stop them touching the discs? Discs 32.6mm & 32.9mm
8. Noise coming from front engine area. Probably the thermostat housing O ring but will need to have bumper off to inspect.
9. N145 right solenoid engine mount defective.
10. Replace brake fluid.
BTW... Hate to break it but DRC, OIL Cooler and front disks are 6k alone from stealers....S4WON wrote:Hi BombBomb_Doctor wrote:1. Rear Washerjet blocked.adsgreen wrote:.............What other things did they find?
Some of these are pretty common DRC. Oil cooler etc and you could've saved yourself some cash if you'd come here sooner...
Anyway, it is incredibly unlikely these issues went overnight. Do you have any comeback or was it a private sale?
If any comeback get on their case ASAP if private what did you pay? Pointing out the obvious but if cheap here is your reason why.
If its a keeper and you don't want Audi warranty get the work done at a specialist and save a few quid.
AMD is in Essex
MRC in Oxford
UNIT 20 up north!
GL, stick with it, awesome cars when running well
Bomb_Doctor wrote:Without the oil cooler, I've been quoted £2900 from a Stealer.
It was bought from a independent dealer - who is as miffed as I am...as he took it to an Audi Stealer for a service before the sale...they did a health check and came up with totally different issues....some totally opposite and conflicting to the issues bought up in the inspection I had done.......![]()
It had new oil pipes and DRC only a couple of years ago......
I did my research....knew the issues, asked the right questions before sale. The dealer has said he will put any issues right![]()
Have asked MRC for a price for an independent inspection....to hopefully get to the bottom of what actually needs doing. I want to quantify for example....is there slight misting or weeping of DRC or is it full on leakage?
Users browsing this forum: No registered users and 85 guests
