In for sticky clutch investigation
sar
Re: In for sticky clutch investigation
Post by sar » Tue Sep 24, 2013 9:20 pm
victor2vt wrote:I had this happen to me on a recent track day, but no signs since, 2 weeks ago, anyone had this as an intermittent problem ?
yes mate, this is how it starts.
Post by MikeFish » Tue Sep 24, 2013 10:40 pm
It's happened to me twice over the course of about 18 months. Last time was probably 8 months ago.
Noyjatat
Post by Noyjatat » Wed Sep 25, 2013 10:18 pm
Well looks like clutch :D
Will get it changed next month.
Gavla
Post by Gavla » Wed Sep 25, 2013 10:25 pm
Arrgh!! £££££ :bash:
Are you going for a dual mass again?
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
Noyjatat
Post by Noyjatat » Thu Sep 26, 2013 6:40 am
Just gonna get am OEM one fitted
ArthurPE
Post by ArthurPE » Thu Sep 26, 2013 8:34 pm
you can make it stick at will
with car out of gear and clutch depressed rev engine to 6-8k a few times
it will stick
RIV
Post by RIV » Thu Sep 26, 2013 9:01 pm
it will stick
why would you want to make it fail??
adsgreen
Post by adsgreen » Thu Sep 26, 2013 9:07 pm
it will stick
A repeatable problem is something that should be stuffed and mounted on the wall.
Noyjatat
Post by Noyjatat » Thu Sep 26, 2013 9:38 pm
Yeah thats what I have got Arthur. I wonder if anyone else's actually passes this test. At 6,000 it doesn't always happen but up to 8,000 it always does.
ArthurPE
Post by ArthurPE » Fri Sep 27, 2013 2:29 am
it will stick
it's not 'failed', it happens all the time during spirited driving, all you do is pull it out
driving with it stuck also doesn't seem to be an issue, mine disengaged, the pedal just stayed down most of the way, you could still disengage the clutch by pushing the stuck pedal
it's a way to show the dealer exactly what is happening
if it's not repeatable, it's not a problem to them
RIV
Post by RIV » Fri Sep 27, 2013 10:49 am
I'm not even going to comment on the sticky pedal as I don't want to tempt fate :nodder:
Noyjatat
Post by Noyjatat » Fri Sep 27, 2013 2:53 pm
You already have it Silas you just don't know it :D
The people carrier models are less prone due to the soccer mom drivers ;D
Wavey Dynamicist
Post by Wavey Dynamicist » Fri Sep 27, 2013 8:15 pm
Have any of you simply tried to flush the clutch fluid and put some high quality stuff in?
I'm about to tackle this problem and this is where i'm starting.. Who knows what Audi put in there..!
2007 RS4 Saloon; Mugello Blue
RIV
Post by RIV » Fri Sep 27, 2013 8:21 pm
My car is only driven by testosterone :biggrin3:
Noyjatat
Post by Noyjatat » Fri Sep 27, 2013 9:03 pm
You fitted the steering wheel yet?
I am not sure if anybody has done a self service on the clutch but I imagine they have. We already know about the pressure plate issue which has been carried to the JHM ones as they used an OEM one in their clutch so it seems to be an issue specific for the clutch and is normally solved by its replacement.
I took the opportunity to post the changes I have made to add another example, the components changed and the final solve. To be honest unless you drive the car close to limits it doesn't tend to reappear and you will likely get a considerable amount of miles out the car without having to change anything.
Users browsing this forum: Google Adsense [Bot] and 147 guests
