Urgent help road trip tomorrow and really rough idel
Hey Guys,
I appreciate this might be a bit of a how long is a piece of string question but I need urgent help.
When I started my car up from work today i had a really high idle 2k, drove fine all the way home. Then when I got home a re-started and idle is really lumpy. Now this would not be such a massive issue if I wasnt travelling to cornwall tomorrow PM.
I have hooked up the Vagcom and cleared a load of codes (flat battery a few weeks ago). The only code I could see was a bank running lean but no other codes. but no codes have returned.
Can anyone give any advice at all, would really appriciate it!
Re: Urgent help road trip tomorrow and really rough idel
Flat battery? Wonder if the throttle body needs re-aligning? Have you had the air filter box off recently?
Probably an air leak. What's your air flow at idle?
no nothing has been off, funny the flat battery was weeks ago so shouldnt really have an effect. I wonder if MRC could see me first thing?
havent checked the air flow at idle, need to put the baby to sleep first
What should it be mate?
About 5g/s per bank if memory serves. No less than 3, anyway. I'm betting on something simple like a vac leak or bad MAF.
if it is a bad maf is that something that mainsteelers usually stock or Euro's
You can get them at lots of places. Make sure you get genuine Bosch. Bosch remanufactured is fine, too. But gotta be genuine. Not answering any more questions until you sort your punctuation out.
Stroppy sod.
lol, you try typing with a crazed 10 month old in your arms whilst trying to eating dinner!!!!!
right, hooked the Vag-Com up and the results are.
Bit low on bank one. What happens at 2k rpm?
You love it really. Gets you moist.chunky79 wrote:Stroppy sod.
all good at 2k i think mate, why?Shoppinit wrote:Bit low on bank one. What happens at 2k rpm?
Do you think that the low reading on bank 1 could cause my issue?
shall i take another reading at 2k?
