Fault code
Fault code
Bank 1 and Bank 2 secondary airflow insufficient flow ? Management light on. Anyone seen this ?
Re: Fault code
Yes. Fcuk loads of people have seen it. Chunk, where are you with your "Search mofo" comments?
It's a problem with your secondary air injection. It'll be either perished vac pipes, broken recombiner valves or a dodgy pump, possibly a clogged filter. Nothing terribly serious.
Re: Fault code
Sweet !! I've had her 2 month now and this is the first "fault" (excluding GPS antenna) cleared the code so ill wait and see the outcome before getting the Ovies on and spanners out ! Think she's still on the original box as well at 132K !!
Re: Fault code
Well that will go one of two ways, either a "lucky you"RS6Mule wrote:Sweet Think she's still on the original box as well at 132K !!
- Russellj80
Re: Fault code
Check your air box is positioned correctly. You've not had it off lately have you?
Re: Fault code
*snigger*Russellj80 wrote:You've not had it off lately have you?
- Russellj80
Re: Fault code
Snigger all u want Shop it can cause major grief!
- Russellj80
Re: Fault code
.... Not getting it off!! :p
Users browsing this forum: Google [Bot] and 92 guests
