Need some help.
E3ddw
Need some help.
Post by E3ddw » Mon Sep 02, 2013 3:37 pm
What's this part called? As you can see the plastics all flaking off and corroded.
caldy
Re: Need some help.
Post by caldy » Mon Sep 02, 2013 3:40 pm
It's the A pillar mirror trim.
You can buy a carbon fibre cover from Argon Creative but they're a bugger to fit!
RS4 B7 Phantom Black
E3ddw
Re: Need some help.
Post by E3ddw » Mon Sep 02, 2013 3:46 pm
caldy wrote:It's the A pillar mirror trim.
Thanks buddy. Do you know where else I can get it from? I've googled it but ebay keeps coming up something totally different.
decarbon8
Re: Need some help.
Post by decarbon8 » Mon Sep 02, 2013 4:10 pm
They are around £40 from Stealers if thats any good, part number Right hand side is 8E2 857 540 1P9
Cecilthesausage
Re: Need some help.
Post by Cecilthesausage » Mon Sep 02, 2013 6:13 pm
Mine are the same I am just going to get them powdercoated...
Yanos
Re: Need some help.
Post by Yanos » Mon Sep 02, 2013 8:13 pm
Sar posted a guide to remove the mirrors and base plate. Check it out. Getting re sprayed should be cheaper than new. Mine are the same so getting them done soon
RS4 B7 Misano Red Saloon / Black Optics / Revolution - Pipercross Carbon air intake / Carbon Clean / Black Rings / Lepsons Black Chrome Alloys
MB2
Re: Need some help.
Post by MB2 » Tue Sep 03, 2013 12:01 pm
Given they look like they are alluminium it may be worth getting them anodised rather than painted/powder coated ?
WillRS
Re: Need some help.
Post by WillRS » Tue Sep 03, 2013 12:48 pm
the only thing i'd say about respraying is that the parts are pretty cheap anyway (£44) and by the time you've masked off really carefully and or removed them to spray them you might as well have replaced them. (in my opinion)
my drivers side one has definitely been sprayed in the past as there's a tiny bit of overspray on the paintwork just below the silver trim strip. as well as that slight annoyance which needs tidying up, the base has bubbled up again and needs doing again (or replacing)
Yanos
Re: Need some help.
Post by Yanos » Tue Sep 03, 2013 3:06 pm
WillRS wrote:the only thing i'd say about respraying is that the parts are pretty cheap anyway (£44) and by the time you've masked off really carefully and or removed them to spray them you might as well have replaced them. (in my opinion)
Very true. I am taking my mirrors off to get them sprayed anyway so its not a major job to take the base plate too. The shop I use is doing them for 30 a side, mirrors and base plate
