Newbe says Hi & seeks advice on buying
Bomb_Doctor
Post by Bomb_Doctor » Tue Sep 03, 2013 11:37 am
Good day to you all :)
I've been lurking for a while now whilst searching for the right car...I think I may have found it - 06 Avant. I've read the sticky on buying. I'm new to Audi having had a varied car career so far...but including Marcos LM500 & Monaro. Living in the South Midlands area.
I took the Avant for a test drive the other day and noticed a couple of things...
1. A bit smokey on start up - dark sooty smoke.
2. Ran quite rough until about 10 minutes into the drive.
3. The front discs had a pronounced lip on the outer edge. Guessing they're worn...but what is acceptable?
Any ideas/views??
Bomb Doctor
S4WON
Re: Newbe says Hi & seeks advice on buying
Post by S4WON » Tue Sep 03, 2013 12:29 pm
ill give you the non technical summary...
move on, im sure you are in love with it, but the shouldnt smoke and shouldnt be lumpy for 10 mins
what is your budget and spec wish list?
spikeyboy101
Post by spikeyboy101 » Tue Sep 03, 2013 1:08 pm
As S4WON has said probably best to move on with the dark sooty smoke at start up.
But if you are still interested the front Disks start at 34mm and min tollerance per Audi is 32mm
edge
Post by edge » Tue Sep 03, 2013 1:09 pm
Have to agree with the guys, keep hunting!
toyneg
Post by toyneg » Tue Sep 03, 2013 2:15 pm
Try and buy from a forum member if at all possible. that way you know it has more chance of being looked after by an enthusiast
good luck with the search
toshers
Post by toshers » Tue Sep 03, 2013 2:59 pm
As above, run away from this one! Plenty more out there...
New RS6 PE ordered in Nogaro...it's a long wait!
2015 Suzuka Grey RS4
Bomb_Doctor
Post by Bomb_Doctor » Tue Sep 03, 2013 4:06 pm
Thanks for the replies..... My ideal car would be a 07 plate (Avant), Daytona grey with as much spec as possible, with the lowest miles.....for circa £21k :)
Any ideas what the smokey start up could be a sign of? It comes with 12 months RAC warranty ;)
Post by MikeFish » Tue Sep 03, 2013 4:12 pm
Has it been modified? Mine gives a puff of smoke when cold as it has no pre cats.
MB2
Post by MB2 » Tue Sep 03, 2013 4:59 pm
I wonder what SW release it is on as it could maybe have missed up the recalls as I think 0090 was for smoky start up ? I do agree though if it is below going rate then there could well be a reason & a bargain now could easily become a nightmare later when you find the warranty isn't quite as comprehensive as you first hoped...
PetrolDave
Post by PetrolDave » Tue Sep 03, 2013 5:34 pm
MB2 wrote:I wonder what SW release it is on as it could maybe have missed up the recalls as I think 0090 was for smoky start up.
SW0090 was never a recall, it was on owner request only and even then only if you "gave the right answers"- and some Audi dealers said (still say) that there's no such thing as SW 0090 :audibash:
sync24
Post by sync24 » Tue Sep 03, 2013 7:13 pm
FYI Removal of precats will give a puff of dark grey smoke on start. Post warm up to 70c and then the first 8000rpm pull will smoke also at gear change after that no smoke at all.
lengster1
Post by lengster1 » Tue Sep 03, 2013 7:22 pm
They do smoke from cold if they've been pootling around a lot,and Defoe do when running sports or no cat down pipes,they also run rough from cold until fully warmed through,worse if cheap low octane fuel is used,lipped discs wouldn't put me off a straight decent car just make sure it's factored into the purchase price,I'd be more concerned with knackered side bolsters and crash damage as you ain't sortin these afterwards easily.
TonyHayers
Post by TonyHayers » Tue Sep 03, 2013 7:30 pm
Mine smokes a fair bit and doesn't have a molecule of carbon in the manifold :) No precats though.
06 Phantom Black Saloon:
^ GONE :cry:
Bomb_Doctor
Post by Bomb_Doctor » Tue Sep 03, 2013 8:29 pm
Damn it.....some for...some against :( :)
MB2
Post by MB2 » Tue Sep 03, 2013 9:43 pm
Look at a few & you will soon get to tell a good un from a potentially bad one.
Users browsing this forum: Baidu [Spider], Google [Bot], Majestic-12 [Bot] and 95 guests
