DRC and tyre pressures - am I wrong?
Since I got my RS4 I've always used 38/35psi as per the label in the door. The car doesn't seem to handle as well even a few PSI above or below that, although it might just be my imagination.
I've often wondered if the DRC, with it's diagonally linked dampers, somehow magnifies the effects of under/overinflated tyres.
Is there any milage in that theory? I'd love to know.
Re: DRC and tyre pressures - am I wrong?
Ive just bought a "new to me" B7 RS4 and am also curious about tyre pressures. as the OP says, the offical pressures are 38/35 yet from my touring of the internet, it seems everyone has a different idea of what is correct.
Any info from the B7 pros on tyre pressures for 255 35 19s much appreciated, if it makes any difference im running Michellin Super Sports.
thanks
thanks
I run 35 all round on my Goodyear Eagle F1 Assy 2s
C7 RS6 Daytona Grey
06 Sprint Blue Saloon- Sold (awesome car)
KikapuRS wrote:I run 35 all round on my Goodyear Eagle F1 Assy 2s
To low imo, to low for the fronts due to engine, bet those babies heat up quickly.
My tyre guy recommended 40/38 in my 275/30/19's using nitrogen
Been very happy with that
And as thy don't heat up like air probably similar to 38/35 pressures
Graze
Graze
Current
V12 Vantage S
Sold
2007 B7 RS4, Ibis white, 8mm spacers, carbon chin spoiler
2001 B5 RS4, Metallic Black, Neuspeed rear ARB, 275/30/19's + 10mm spacers on B7 RS4 wheels! 034 motor mounts, APR snub mount, JHM shortshifter, 18Z calipers & slotted rotors, custom FBSW
V12 Vantage S
Sold
I see your point Sonny, my logic was that the contact patch would be greater, especially under braking, therefore improving front end grip. Interestingly enough the fronts aren't wearing at an excessive rate, maybe I need to push harder! !sonny wrote:KikapuRS wrote:I run 35 all round on my Goodyear Eagle F1 Assy 2s
To low imo, to low for the fronts due to engine, bet those babies heat upsonny wrote:KikapuRS wrote:I run 35 all round on my Goodyear Eagle F1 Assy 2s
C7 RS6 Daytona Grey
You will compromise on handling and fuel economy. On track i dropped to 40psi hot from standard pressures. This puts them at 33 cold, however i would never go out on track with them tat low im not made of money lolKikapuRS wrote:I see your point Sonny, my logic was that the contact patch would be greater, especially under braking, therefore improving front end grip. Interestingly enough the fronts aren't wearing at an excessive rate, maybe I need to push harder! !sonny wrote:KikapuRS wrote:I run 35 all round on my Goodyear Eagle F1 Assy 2s
Sorry to break it to you but nitrogen expands the same as any other gas.The effect is called Charles law and is well known in thermodynamics (co2 filled tyres, n2 filled or even dehumidifier air all expand the same amount).Graze wrote:My tyre guy recommended 40/38 in my 275/30/19's using nitrogen
Graze
The issue is with water moisture which only comes into play when you approach 100c and it turns to steam. If you have road tyres hitting 100c internal temp on the road then you have other issues.
Tried nitrogen and even on track I found it more a pita than anything else.
- PetrolDave
As adsgreen has said ALL gasses expand to the same extent, nitrogen "expanding less than air" is another great 21st Century urban myth.Graze wrote:My tyre guy recommended 40/38 in my 275/30/19's using nitrogen
ok guys...
so do I shoot for 38F and 35R then?
- PetrolDave
When I had 275/30 19" Goodyears I was advised to increase the pressures by 0.1 bar to 2.7 front and 2.5 rear - that's 39F and 36R (and adjust the thresholds on the TPMS accordingly).
[quote]When I had 275/30 19" Goodyears I was advised to increase the pressures by 0.1 bar to 2.7 front and 2.5 rear - that's 39F and 36R (and adjust the thresholds on the TPMS accordingly).
[/quote
Going off topic, did you find when running 275's you suffered with tyre wear on the front inner edge? I've always had 275's ever since I bought my car but have found they scrub quickly, I also get my alignment checked twice a year
[/quote
- Surrey Sam
Silas, I'm wondering if the wider tyres have introduced a tiny bit more negative camber? Your alignment people I presume are keeping to the factory numbers which is optimised for the 255 section tyres, hence a little more wear on the inside edge. Just a guess here
ok', so turns out previous pressure was 35F and 33R. ive pumped up to 38/35 and am very happy with the results, certainly feels less skittish when pushing on.... for interest at the end of the run, the temps were approx 4 psi higher all round.
You could well be correct Sam, I'm thinking about changing back to the standard size tyresSilas, I'm wondering if the wider tyres have introduced a tiny bit more negative camber? Your alignment people I presume are keeping to the factory numbers which is optimised for the 255 section tyres, hence a little more wear on the inside edge. Just a guess here
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 86 guests
