Avus Avant 2008 sloooow build
hlbeckley
Re: Avus Avant 2008 should I?....So i did!
Post by hlbeckley » Tue Aug 20, 2013 3:15 pm
One more thing, I find as you peal and get to the edge of the badge you pull the dip sheet away from the badge and gently
TonyHayers
Post by TonyHayers » Tue Aug 20, 2013 3:53 pm
Interesting. I'm getting tempted to actually give it a try on my silver window trims.
06 Phantom Black Saloon:
^ GONE :cry:
hlbeckley
Post by hlbeckley » Tue Aug 20, 2013 6:03 pm
If u do, buy the cleaner too. Helps keep the surface free from oil or waxes that build up from washing. That will help give a better finish
hlbeckley
Post by hlbeckley » Sat Aug 24, 2013 7:25 pm
KernowPete
Post by KernowPete » Sat Aug 24, 2013 9:59 pm
TonyHayers wrote:Interesting. I'm getting tempted to actually give it a try on my silver window trims.
Me too. Anybody any idea which plastidip coulour is closest to OEM silver trim?
2007 B7 RS4 Phantom Black Saloon - stock
Previous: Lightly modded Mondeo ST220 (great car), nothing else worth mentioning!
hlbeckley
Post by hlbeckley » Sun Aug 25, 2013 8:05 am
They don't make a silver yet!
They do a "true metallics anthracite" though which is almost the same as 8AU colour code for the titanium spec mirrors and wheels
hlbeckley
Post by hlbeckley » Sun Aug 25, 2013 2:52 pm
Before
After
Next up
RS4pete
Post by RS4pete » Sun Aug 25, 2013 4:18 pm
seriously contemplating this .... can you show a close up of the finish please? Any plans to do the window trims and roof rails?
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit :)
hlbeckley
Post by hlbeckley » Sun Aug 25, 2013 5:23 pm
Roof rails were painted black before I got the car and the wheels were Ti, so I am just completing the black optics
Rear badge done but its not perfect so will re do it
hlbeckley
Post by hlbeckley » Sun Aug 25, 2013 5:34 pm
RS4pete wrote:seriously contemplating this .... can you show a close up of the finish please? Any plans to do the window trims and roof rails?
I went for matt finish so there is some texture but you can get gloss look with a glossifier
Here is a decent Pre-peal pic
RS4pete
Post by RS4pete » Sun Aug 25, 2013 5:44 pm
and the window trims?
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit :)
hlbeckley
Post by hlbeckley » Sun Aug 25, 2013 5:58 pm
Haven't done the window trim yet, I am getting comfortable with the small bits, but I recon they are next!
It's honestly so easy, just lots of light coats and allow to dry between each coat! So it takes time but this gives a smoother finish and when u build up layers, the pealing process is a lot easier.
Can't say this enough, but go check out Fonzi on YouTube at dipyourcar
Did this today too
sakimano
Post by sakimano » Fri Aug 30, 2013 4:27 am
We should start the 'Faux Ti Avus Silver Owners' Club '
FTASOC lol
How about the rear rings? And did you consider doing the R entirely black?
You could easily 'saw' the RS 4 and rings off with dental floss and then have better Co tool when spraying them. Then just reapply with auto badge adhesive from 3m.
hlbeckley
Post by hlbeckley » Fri Aug 30, 2013 11:05 am
Think i may have to do that Saki with the RS badge to get the red block perfect.
So i have done the rear rings now, the RS badge (thinking of doing the flank ones too) and the front grill surround.
Looking at the mirror removal may try that next and pull it off if it looks sh1t
sakimano
Post by sakimano » Fri Aug 30, 2013 8:17 pm
hlbeckley wrote:Think i may have to do that Saki with the RS badge to get the red block perfect.
Ive done the front grille same as you (our pictures look very similar funny enough...I think we discussed this in the b7 RS4 pic thread). I still want to do:
a) rear rings
b) window trim
I will not bother with the mirror caps. For the window trim, I can't see myself being patient enough to do it well, so I will likely just go to a vinyl wrap company and have them do it. A place here has offered to do it for $200 which seems a bit expensive, but hopefully a few of us can band together and get a better deal. I wouldn't vinyl wrap it on my own. It's apparently tough to get the corners right.
plastidip would be pretty easy on the window trim but as I said tough to block off the entire car and not go crazy lol
after 800 kms...
Users browsing this forum: Majestic-12 [Bot] and 350 guests
