Windsreen Washer Upgrade
I found Audi actually make a kit to upgrade the washer jets from 2 nozzles to the later tri-jets (4F0 098 101) so I ordered it to tri out.
When the kit arrived it consisted of a set of Audi tri-jet heated washers (8J0 955 987 G & 8J0 955 988 G) with some spacers that fit to the bonnet to make them fit. It also came with a CD that showed how to align the jets for the windscreen - it seems a decent upgrade for the sake of 5 minutes to fit.
I also had a set of Passat fan jets 5M0 955 986 C which also fit fine with the spacers too. They are much better nozzles as spray an even mist onto the screen & also adjust quite neatly with a T-10 rather than messing about with pins but even at the highest alignment seem a little low vs the Audi nozzles.
In summary I think the tri jets are the best for the A4 as with the fans you have to sync the washing a bit to avoid washing the wiper arms instead of the windows as they aren't really at the right angle but both will work.
In don't know if the parts are avaialable separately but if anyone wants to build their own kit the PN for the spacers is as follows - then just add the jets of your choice.
8E0 955 431 - will need 2 pieces
- Firestarter
Re: Windsreen Washer Upgrade
Nice little upgrade that MB2
What did the kit cost?
I see you say "will need 2 pieces" and assume that's 2 x 8E0 955 431
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
I think the kit was about 35 but if they sell the spacers by themselves then I expect would be much cheaper to buy the components rather than the kit itself.
Yes - one spacer for each jet.
- Firestarter
Nice one CheeRS buddy
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
No problem - just put the PNs in for the tri-jet washers (unlike the Passat jets they are handed) so all the PNs in the one post.
Great stuff! One of my drivers side nozzles has become self aware and randomly fires wherever it wants.
Where did you order from? I'm keen to get some.
RS4 B7 Misano Red Saloon / Black Optics / Revolution - Pipercross Carbon air intake / Carbon Clean / Black Rings / Lepsons Black Chrome Alloys
How are they heated?
There is a 2 pin plug that clips onto the back of the washer jets (same fitting on the 2 jet, 3 jet & fan jets) I guess is just a short circuit that comes on with the ignition to warm the assembly up.
Ordered the kit through Audi & would expect have to do the same for the spacers although am sure the washer jets will also be on eBay.
Thanks MB2 will get this ordered up, mine are cakaMB2 wrote:There is a 2 pin plug that clips onto the back of the washer jets (same fitting on the 2 jet, 3 jet & fan jets) I guess is just a short circuit that comes on with the ignition to warm the assembly up.
Will take all of 5 minutes to fit & if you are looking at buying new jets anyway well worth going for these instead. Aiming is a bit tricky best bet is to use a dry-wipe marker, mark the points on the windscreen then copy them to the inside of the screen then adjust with a long pin or better a small socket over the jets.
Oh so the OEM ones are already heated? I didn't know that!MB2 wrote:There is a 2 pin plug that clips onto the back of the washer jets (same fitting on the 2 jet, 3 jet & fan jets) I guess is just a short circuit that comes on with the ignition to warm the assembly up.
My drivers side outer jet has just started playing up again so this is well timed. I've got to go in Audi's to get some rocker cover gaskets for mine so will order this kit while I'm in there. Just for clarity am I right in saying the kit number is: 4FO 098 101?
Previous car: 2005 S4 B7.
Yup new ones needed anywho so these will be better! Aiming them with a safety pin works for me, we used re-aim peoples jets at work to spray off to the pavement. Made for comical city driving.MB2 wrote:Will take all of 5 minutes to fit & if you are looking at buying new jets anyway well worth going for these instead. Aiming is a bit tricky best bet is to use a dry-wipe marker, mark the points on the windscreen then copy them to the inside of the screen then adjust with a long pin or better a small socket over the jets.
batfinnk have you checked availability of those gaskets?, im sure one side is a revised part and only available with a new rocker cover itself...£££. hope im wrong.Batfinnk wrote:My drivers side outer jet has just started playing up again so this is well timed. I've got to go in Audi's to get some rocker cover gaskets for mine so will order this kit while I'm in there. Just for clarity am I right in saying the kit number is: 4FO 098 101?
Just ordered the kit from Audi, its cheaper than I could find on ebay or other online places.
Heres what they sent me re parts list:
Users browsing this forum: No registered users and 330 guests
