Windsreen Washer Upgrade
MB2
Post by MB2 » Mon Aug 05, 2013 11:47 am
I found Audi actually make a kit to upgrade the washer jets from 2 nozzles to the later tri-jets (4F0 098 101) so I ordered it to tri out.
When the kit arrived it consisted of a set of Audi tri-jet heated washers (8J0 955 987 G & 8J0 955 988 G) with some spacers that fit to the bonnet to make them fit. It also came with a CD that showed how to align the jets for the windscreen - it seems a decent upgrade for the sake of 5 minutes to fit.
I also had a set of Passat fan jets 5M0 955 986 C which also fit fine with the spacers too. They are much better nozzles as spray an even mist onto the screen & also adjust quite neatly with a T-10 rather than messing about with pins but even at the highest alignment seem a little low vs the Audi nozzles.
In summary I think the tri jets are the best for the A4 as with the fans you have to sync the washing a bit to avoid washing the wiper arms instead of the windows as they aren't really at the right angle but both will work.
In don't know if the parts are avaialable separately but if anyone wants to build their own kit the PN for the spacers is as follows - then just add the jets of your choice.
8E0 955 431 - will need 2 pieces
Firestarter
Re: Windsreen Washer Upgrade
Post by Firestarter » Mon Aug 05, 2013 12:04 pm
Nice little upgrade that MB2 :thumb: :beerchug: :thumb:
What did the kit cost?
I see you say "will need 2 pieces" and assume that's 2 x 8E0 955 431
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT :-)
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre :-)
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
MB2
Post by MB2 » Mon Aug 05, 2013 12:28 pm
I think the kit was about 35 but if they sell the spacers by themselves then I expect would be much cheaper to buy the components rather than the kit itself.
Yes - one spacer for each jet.
Firestarter
Post by Firestarter » Mon Aug 05, 2013 12:48 pm
Nice one CheeRS buddy
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
MB2
Post by MB2 » Mon Aug 05, 2013 1:03 pm
No problem - just put the PNs in for the tri-jet washers (unlike the Passat jets they are handed) so all the PNs in the one post.
Yanos
Post by Yanos » Mon Aug 05, 2013 7:31 pm
Great stuff! One of my drivers side nozzles has become self aware and randomly fires wherever it wants.
Where did you order from? I'm keen to get some.
RS4 B7 Misano Red Saloon / Black Optics / Revolution - Pipercross Carbon air intake / Carbon Clean / Black Rings / Lepsons Black Chrome Alloys
Post by MikeFish » Mon Aug 05, 2013 7:36 pm
How are they heated?
MB2
Post by MB2 » Mon Aug 05, 2013 9:20 pm
There is a 2 pin plug that clips onto the back of the washer jets (same fitting on the 2 jet, 3 jet & fan jets) I guess is just a short circuit that comes on with the ignition to warm the assembly up.
Ordered the kit through Audi & would expect have to do the same for the spacers although am sure the washer jets will also be on eBay.
Yanos
Post by Yanos » Mon Aug 05, 2013 9:42 pm
MB2 wrote:There is a 2 pin plug that clips onto the back of the washer jets (same fitting on the 2 jet, 3 jet & fan jets) I guess is just a short circuit that comes on with the ignition to warm the assembly up.
Thanks MB2 will get this ordered up, mine are caka
MB2
Post by MB2 » Mon Aug 05, 2013 9:50 pm
Will take all of 5 minutes to fit & if you are looking at buying new jets anyway well worth going for these instead. Aiming is a bit tricky best bet is to use a dry-wipe marker, mark the points on the windscreen then copy them to the inside of the screen then adjust with a long pin or better a small socket over the jets.
Post by MikeFish » Mon Aug 05, 2013 9:57 pm
Oh so the OEM ones are already heated? I didn't know that!
Batfinnk
Post by Batfinnk » Mon Aug 05, 2013 10:02 pm
My drivers side outer jet has just started playing up again so this is well timed. I've got to go in Audi's to get some rocker cover gaskets for mine so will order this kit while I'm in there. Just for clarity am I right in saying the kit number is: 4FO 098 101?
Previous car: 2005 S4 B7.
Yanos
Post by Yanos » Mon Aug 05, 2013 10:09 pm
MB2 wrote:Will take all of 5 minutes to fit & if you are looking at buying new jets anyway well worth going for these instead. Aiming is a bit tricky best bet is to use a dry-wipe marker, mark the points on the windscreen then copy them to the inside of the screen then adjust with a long pin or better a small socket over the jets.
Yup new ones needed anywho so these will be better! Aiming them with a safety pin works for me, we used re-aim peoples jets at work to spray off to the pavement. Made for comical city driving.
sar
Post by sar » Mon Aug 05, 2013 10:35 pm
Batfinnk wrote:My drivers side outer jet has just started playing up again so this is well timed. I've got to go in Audi's to get some rocker cover gaskets for mine so will order this kit while I'm in there. Just for clarity am I right in saying the kit number is: 4FO 098 101?
batfinnk have you checked availability of those gaskets?, im sure one side is a revised part and only available with a new rocker cover itself...£££. hope im wrong.
Yanos
Post by Yanos » Tue Aug 06, 2013 9:29 am
Just ordered the kit from Audi, its cheaper than I could find on ebay or other online places.
Heres what they sent me re parts list:
Users browsing this forum: No registered users and 308 guests
