Fuel consumption
Fuel consumption
Recently went on a round trip to Devon, around 547 miles. Used remaining fuel driving around town so totalled around 657 miles before filling up again. Worked out mpg which came to a eager 15.7 mpg!!! I was very careful on the long run a basically cruised at around 75 mph with just a couple of bursts. The S4 is thirsty I know, but I really expected a much better mpg than this especially in view of the long run which was mostly motorway driving. Appreciate any thoughts or ideas on how I can get better performance out of what is a terrific car. Black S4 saloon 6 years old around 51400 miles.
Paul
Paul
Re: Fuel consumption
I filled up, I drove from Exeter to MRC, 190 miles. Used nearly a full tank. Filled up at Tesco near MRC, re-mapped and drove home, filled up again when back in Exeter as it was low. Call it 400 miles, 2 tanks of fuel. Haha
I get 13 mpg around town
Ps 657 miles on 63 ltrs is 47mpg which is mental haha
My best is 142 miles from full to the dis beeping saying I had 35 miles left until empty. Felt quite proud of that as it was just after having my exhaust modded so it was down to gentle use
Previous car: 2005 S4 B7.
Woah, there's something not right there !
I get an average of 22 MPG and that's with spirited driving.
I recently went to Le Man and from Newcastle I got 350 odd miles to a tank. That's my record.
I would check out your fuel trims with Vag-Com or via a dealer. They must be way out.
Have you had the lambda sensors changed, at all? They're only good for 70-80 thousand miles and they control the fueling.
There's defo' something not right with your car - check the fuel trims first.
Regards, Chris.
Regards, Chris.
- BlingBling
Agreed. MW cruising 70-80 will easily yield 24mpg. That will include several WOT moments and the odd blast beyond 3 figures. The above without WOT and 3 figures will get me 26mpg tops.
That 15.7 mpg figure is insane!
I've seen just shy of 30mpg mincing up and down the motorways in mine (legal speeds, cruise on), its an auto which is allegedly slightly easier on consumption.
Round town is a totally different story though..
There was a hint of humour when I said 142 was my best. I normally average between 290 and 340 to a tankful.
Here's my technique for getting in excess of 30mpg on a motorway
Boot it up hills until you reach a speed your uncomfortable at, then tickle it over the top and coast it downhill in gear. Tickle it along the flats and watch well ahead of you so you never have to brake.
Works for me, then you have more fuel to 'play', I find my B6 more economical and smoother on the BP Ultimate
xyber, if u don't mind me asking, what ipad app are using for those screenshots. I need something like that as it saves me setting up my own spreadsheets!!xyber wrote:
Smyffie
Road trip HD I think its called, on ipad.
Think they do phone versions to.
I have it on my iPhone. Free if you take road trip lite. Only restriction is limited to 1 car.
I had my S4 converted to LPG, about £37 in gas gets me on average 240 miles. You lose a bit of power but its also switchable between gas and petrol so if I want a bit of fun switch it over to petrol and it feels quicker. I couldn't recommend it enough especially if you do a lot of miles like myself.
I loved my B7 S4 but I still shudder when I think about how much fuel I used to get through. My B8 gives me nearly 300 miles per 55 litre fill up which is about 100 more miles than my B7!
Still miss that noise though!
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Past:
Users browsing this forum: No registered users and 20 guests
