http://www.ebay.co.uk/itm/Audi-A4-B7-RS ... 53fb98665c
Rear Discs for £32.86!
Re: Rear Discs for £32.86!
Those are most definitely not what you want for your B7 RS4!
The rear brakes are drilled, vented and floating 324 millimetres (12.8 in) by 22 millimetres (0.87 in) iron discs, with gloss black Lucas-Girling TRW single piston floating calipers with an integrated mechanical handbrake mechanism.
This is what they should look like! Pic 2 of 2
http://www.stokeaudi-parts.co.uk/produc ... ct_id=1190
Those are the fronts
rear disks are not floating they are 1 piece, pic above is of front disk? but you are right they are 324 x 22
Go to pic 2 of 2 boys, I did put it in the thread. Unfortunately it automatically puts up pic 1. I do try.
As for floating, my bad just copy pasted from Wiki. Just trying to stop someone from buying those discs thinking they were getting what they have fitted.
Gaz is right, pic 2 is the rear disc.
That eBay one is a solid 255mm diameter and only 12mm thick!!! That's a big difference!!!
Never ceases to amaze me some of the dodgy tat being openly sold on fleabay - if you go on there and search for less than 5 mins you'd be convinced that you could replace discs and pads front + rear on a B7 RS4 for about £150.... which as we all know, is never going to happen
It's clearly the totally wrong parts, but loads of them are up for sale day in day out
Read their disclaimer at the bottom, as always, READ THE small print !!
Mint Optic Pack saloon in Daytona Grey (Now sold)
B7 RS4 in Sprint Blue (Gone to a very good new home)
Evo V1 (wish i'd kept)
Numerous M3s
Numerous M3s
- TonyHayers
- 5th Gear
Are we sure the OP isn't being sarcastic? note the wink.
06 Phantom Black Saloon:
^ GONE
^ GONE
I posted this link a while back - yawn
Im sorry i know its been covered but how can they be wrong?http://www.ebay.co.uk/itm/160974940721
It says 3 have sold so people have tried them, anyone???
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift
- Surrey Sam
The picture on the box depicts them as solid faced discs and as you'll probably be aware - the rears on RS4's are drilled. Then there is the overall diameter; the ones on the eBay advert are described as 300mm whereas I believe the rear OEM discs OD (outside diameter) is 324mm from memory. Lastly there is the manufacturer?
Trying to run an RS4 on a shoe string budget is only asking for trouble, rather you than me.
- Robnic
These will cost you - the return postage for your credit because they don't fit
B7 RS4 MTM K540 Sprint loon, Lysholm/Opcon twin-screw supercharger, Ceramics, HEL Hoses, Loba SM Fly, Sachs performance clutch kit, MTM full stainless exhaust system with freeflow cats & quad valved tailpipes, Hotchkis ARB's, Bilstein B16 Coil Overs, LED Rear lights, Interior & LED 50W DRL's, Buckets in race cloth, Black optics, FBSW, Titanium pack, Solar Sunroof, Adaptive lights, MTM 10mm spacers Fr & Rr, 193 Nav unit, 2nd careful owner
Users browsing this forum: Google [Bot] and 360 guests
