Air-con problem
STURS4
Re: Air-con problem
Post by STURS4 » Mon Jul 15, 2013 4:04 pm
Ive got the same problem.been upto the garage and the high pressure switch isnt working.Use him all the time and he said the bumper needs to come off,researched on here and its saved me £££££££££ :beerchug:
STURS4
Re: Air-con problem
Post by STURS4 » Tue Jul 16, 2013 4:03 pm
I've just been told that you need to initialise
The system which is why the bumper needs to come off,is this the case?
Re: Air-con problem
Post by Shoppinit » Tue Jul 16, 2013 4:05 pm
:shock:
STURS4
Re: Air-con problem
Post by STURS4 » Wed Jul 17, 2013 12:36 am
Does that mean its bollocks?
Re: Air-con problem
Post by Shoppinit » Wed Jul 17, 2013 7:44 am
It certainly sounds like bollocks to me. Doesn't make any sense. Just had a look at the procedure for G65 - makes no mention of "initialising the system". Just whip the switch out, whip a new one in and bob's your uncle.
Re: Air-con problem
Post by chunky79 » Wed Jul 17, 2013 8:04 am
Depends on if the air con system seals when the switch is removed (very much doubt it) , if not then best of luck. The air con gas is not good for you or anyone else!! Best thing to do is drain the system, change the switch then re-gas. You have to be registered to handle air con gas aswell, me is registered.
Just a note, you can be prosecuted for releasing air con gas onto the atmosphere.
Re: Air-con problem
Post by Shoppinit » Wed Jul 17, 2013 8:16 am
My understanding is that it self-seals when you remove the switch.
Manual wrote:The refrigerant circuit remains closed - connection with valve.
I admit, it's a bit ambiguous, though. Maybe someone who has done it can chime in?
STURS4
Re: Air-con problem
Post by STURS4 » Sat Jul 20, 2013 2:49 pm
So i changed the pressure valve yesterday,simply screws off,no gas leak,screw the new one in,plugged the cable back in,job done all working.could'nt believe my mechanic wanted to charge me 5 hours labour to do the job.he has just lost a regular customer
Re: Air-con problem
Post by Shoppinit » Sat Jul 20, 2013 2:51 pm
That's shocking! Even to remove & replace the bumper it's only an hour... taking your time.
Russellj80
Re: Air-con problem
Post by Russellj80 » Wed Aug 14, 2013 8:47 am
These mechanics will always try to baffle you in order to line their own pockets. There is no gas leak because there is some kind of schrader/pesto valve inside the switch. As soon as you unscrew it the system remains fully sealed!
Re: Air-con problem
Post by Shoppinit » Wed Aug 14, 2013 9:13 am
Mmm. Pesto.
Mr Footlong
Re: Air-con problem
Post by Mr Footlong » Wed Aug 14, 2013 9:16 am
Pesto makes me gag :(
Current:
Gone:
Re: Air-con problem
Post by chunky79 » Wed Aug 14, 2013 9:02 pm
I didn't know that, good to know! (about it self sealing that is)
Russellj80
Re: Air-con problem
Post by Russellj80 » Wed Aug 14, 2013 9:09 pm
Lol
Users browsing this forum: No registered users and 278 guests
