Help req'd - Tyre Pressure Warning
5.0 V10 50v biturbo - 571 bhp
weedub
Post by weedub » Mon Jul 15, 2013 5:45 pm
I have started to get a Tyre Pressure Warning whenever I start the car. I have checked the tyres and all are OK. I have displayed the tyre pressures on the MMI and all Ok there too.
Anyone encountered something similar?
Audi C6 RS6 Avant - Miltek Exhaust - Mugello Blue VW 6R Polo GTI - APR Stage 2 - Black 2006 Subaru Forester XT Luxury - Stock - Black
C6NVS
Re: Help req'd - Tyre Pressure Warning
Post by C6NVS » Mon Jul 15, 2013 6:02 pm
Likely a flat battery in the TPMS.
Have you tried resetting in the MMI.
Have you got a Vagcom to get the fault code, and if not, where you located?
Daytona C6 RS6 Avant: Demand Engineering Exhaust (Downpipes custom to tip)
Soon to add: Hybrid Turbos; Uprated Gearbox; Marston Intercoolers; ECU / TCU mapping
doodlebug
Post by doodlebug » Mon Jul 15, 2013 6:07 pm
What's the warning? Is it actually moaning about a deflation? If you go to the menu with the tyre pressures you'll be able to see exactly what it's moaning about.
It's been warm so could be that something has tipped it over. If the pressures are good, store them and are if it clears.
How old is the car? Battery life is 5 years IIRC.
Noyjatat
Post by Noyjatat » Mon Jul 15, 2013 7:46 pm
Yep I took mine to my local Audi guys who are great. Admitted this was on my B7.
I had put an even amount of pressure in each I stead of what was on the door pillar. The Audi tech told me if the car senses a mismatch of 4 or 5 psi it will flag it to you with the yellow warning prompting.
If you haven't already, set the pressures all round to exactly what it says on the door pillar and run a tyre check after a few miles.
Also found out Audi can test each sensor for faults individually.
Good luck buddy
