Sat-Nav
Re: Sat-Nav
Then Fakra's no fakrin good.
Re: Sat-Nav
Neithers the other one !! There lies my problem. Where should I be slaving the new antenna into ? Where the original one connects into the loom or at the unit ?
Re: Sat-Nav
Connects right to the back of the head unit.
Re: Sat-Nav
Ok so is there an after market antenna with a male co-ax plug ?
Re: Sat-Nav
It's an SMB connection IIRC. Something like this:
http://item.mobileweb.ebay.co.uk/viewit ... 0511815080
Re: Sat-Nav
Ok , I have one of them , doesn't fit where I'm trying to fit it. The only connection I can see similar is mid r/h (looking from front ) on the back of the head unit with a black locking clip , but the antenna plug I disconnect has a male connection and the eBay antenna have female connections. Am I looking in the wrong place ?
Re: Sat-Nav
Hi , how do you get access to the roof mounted antenna ? Through the roof light ?
Re: Sat-Nav
Yes.
Re: Sat-Nav
This is the gps connector on the RNS-D:
The end on your GPS antenna should look like this:
Re: Sat-Nav
Yep - that's the one - over on the LHS when viewed from the front!
Re: Sat-Nav
Hi , cheers , just found a pic , I was trying one of the fm/am antenna plugs !! Cheers.
Re: Sat-Nav
Re: Sat-Nav
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Users browsing this forum: No registered users and 258 guests
