Swapping to 20" alloys, is it all worth it?
- MartayMcFly
- 5th Gear
Re: Swapping to 20" alloys, is it all worth it?
Yup, looks like my calculations from Adrian's setup were off. His wheels are only 9" wide at ET20/22 (after spacers), not 9.5". I'll still try just to make sure, but looks like I'll need to step down to 35mm adapters to be safe, since there's not a 40mm version.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
SorryMartayMcFly wrote:Yup, looks like my calculations from Adrian's setup were off. His wheels are only 9" wide at ET20/22 (after spacers), not 9.5". I'll still try just to make sure, but looks like I'll need to step down to 35mm adapters to be safe, since there's not a 40mm version.
2010 911 Turbo PDK.
Gone but not forgotten... Sprint Blue B7 RS4 with all the toys
20" AG M310's | TTS Supercharged | MRC Stage 3 | Sach's Clutch | Lightened / balanced flywheel | High Pressure Fuel Pumps | KW V3's Coilovers | De-Cat + Valved Milltek | DeCoked | Launch Control | Flat Shift | Cold Air Feed Induction.
35mm would work well with 265 tyres (effectively giving you another 5mm width either side if the wheel) if only you could get them at the same profile as 255, but I don't think there is a combo that works. 265/30/20 will be taller than 255/30/20 and will give you rubbing issues. To give you an idea of how fine the tolerances are I rub on the back with standard suspension and 265/30/20 on 9" wheels with ET26!!!! And that's with no passengers or spacers, but 255/30/19 on a 9" wheel with ET29 and 10mm spacer (giving ET19) is fine.
I went down the 20 inch wheel road and after some rubbing issues and the proportions not seeming right for the wheel I chose have eventually come back to the standard 19 inch wheel. Instead I ended up lowering the car and after much play have a stance that I love that has no rubbing issues........yet
Fair play to those who can get the stance right with 20's on though as they do look great
- MartayMcFly
- 5th Gear
If your 265/30R20 rub at ET26, 255/30R20s will likely rub at ET16. I know it's not always as straight forward as the maths suggests (different tyres have sharper shoulders, some stretch more on the same wheel etc etc) but I'm getting more and more used to the idea of getting smaller adapters being a necessary next step. I might even keep going down the path of finding 5x112 wheels I like and spacing them more responsibly.MikeFish wrote:35mm would work well with 265 tyres (effectively giving you another 5mm width either side if the wheel) if only you could get them at the same profile as 255, but I don't think there is a combo that works. 265/30/20 will be taller than 255/30/20 and will give you rubbing issues. To give you an idea of how fine the tolerances are I rub on the back with standard suspension and 265/30/20 on 9" wheels with ET26!!!! And that's with no passengers or spacers, but 255/30/19 on a 9" wheel with ET29 and 10mm spacer (giving ET19) is fine.
Adrian, it's not your fault, I was just getting excited and didn't do my homework properly. If they don't fit... does anyone want some H&R 5x130-5x112 45mm adapters? They're like new.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
- MartayMcFly
- 5th Gear
Wheels are going on tomorrow. As Samuel L Jackson said in Jurassic Park: "Hold on to your butts."
Will report back on whether ET15 is a shade too far for 20"x9J or whether I've just discovered the absolute limit.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
I will let you know in a few weeks what I think
- MartayMcFly
- 5th Gear
Short answer - no, not going to work. Might not rub, but too far out anyway. Will get narrower adapters and try again, these things are properly chunky.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
You could prob get those new turned down pretty cheap.
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
Spaceman_RS4 wrote:You could prob get those new turned down pretty cheap.
I did this to the spacers I had on a previous car took them from 30mm to 27mm
Got to be 20s for me,19s just look to small.
Ok to machine down spacers but need to be alot more careful with adapters
Drive low,park lower
looks really good
the silver trim on black looks great
35mm adapters?!
I ran over 5 types of wheel combo on my old R32 and to be honest was never too concerned about running chunky adapters/spacers because it wasn't in the same stable as the RS, but 35mm ones on a car with over 400hp is it really advisable?
I wouldn't run 20mm ones, maybe I'm being over cautious.
Users browsing this forum: dan32v and 65 guests
