Fogs as DRLs
Daveperc
Re: Fogs as DRLs
Post by Daveperc » Thu Jul 11, 2013 4:10 pm
Hmmmm...
Got the various bits, fitted it.... and it doesn't work! The switch is still in line, so to get the fogs on you need to turn on the side lights too - which I could do before!!
Anyone got the wiring diagramme for the Fogs - I can't find it in the Tech archive - I need to splice in a feed further down the system...
Re: Fogs as DRLs
Post by Shoppinit » Thu Jul 11, 2013 4:38 pm
Looks like it all happens inside the switch, Dave. Fuse 36 takes its feed from the X75 then goes straight to the switch. From the switch, the wires go straight to the fog lights. I can't see a way around this without opening up the switch. I'll keep looking.
Re: Fogs as DRLs
Post by Shoppinit » Thu Jul 11, 2013 4:59 pm
Now I'm confused because I had a look at the 1999 A6 wiring and it's the same.
Daveperc
Re: Fogs as DRLs
Post by Daveperc » Thu Jul 11, 2013 5:00 pm
What colour is the line off the switch to the fog lights - and how do you get the switch out!
Re: Fogs as DRLs
Post by Shoppinit » Thu Jul 11, 2013 5:04 pm
White/green going from switch to fog lights.
Daveperc
Re: Fogs as DRLs
Post by Daveperc » Thu Jul 11, 2013 5:08 pm
OK - I'm off to feed in there!
Daveperc
Re: Fogs as DRLs
Post by Daveperc » Thu Jul 11, 2013 5:13 pm
Ah - there are two white green wires - is the feed the same colour?
Any easy way to get the switch out
Re: Fogs as DRLs
Post by Shoppinit » Thu Jul 11, 2013 5:55 pm
Yes, the 2 wires going to the 2 fog lights are both white/green.
Try this:
http://www.youtube.com/watch?v=1ChBiotNWV4
Daveperc
Re: Fogs as DRLs
Post by Daveperc » Thu Jul 11, 2013 5:56 pm
Thanks - in the end I simply tested both and came to that conclusion - all now spliced in and working - pics to follow when I have the dash back together
Re: Fogs as DRLs
Post by Shoppinit » Thu Jul 11, 2013 6:04 pm
So basically your fogs will be on as soon as the ignition goes on?
Re: Fogs as DRLs
Post by Shoppinit » Thu Jul 11, 2013 6:05 pm
I wonder if you should be using a diode on that splice...
Daveperc
Re: Fogs as DRLs
Post by Daveperc » Thu Jul 11, 2013 6:41 pm
All done - and working!
Don't think it needs a diode as all I have done effectively is bypass the switch poles for the front fogs.
Feed from Fuse 36 using Add-a-fuse gizmo
Splice onto one green/white wire using clip on splice
Fogs as DRLs, without side or headlights, come on with ignition
Thanks to the online help desk along the way!!
Re: Fogs as DRLs
Post by Shoppinit » Thu Jul 11, 2013 7:18 pm
BotchScotch blocks... :bash:
Glad it's working to your satisfaction. :)
Daveperc
Re: Fogs as DRLs
Post by Daveperc » Thu Jul 11, 2013 7:59 pm
Normally I'd agree, but as access was very limited it was easier than trying to solder while standing on my head!
Mr Footlong
Re: Fogs as DRLs
Post by Mr Footlong » Thu Jul 11, 2013 8:04 pm
Christ, who shot the broom?
Current:
Gone:
Users browsing this forum: No registered users and 69 guests
