Removing catalytic converters
5.0 V10 50v biturbo - 571 bhp
Pumpkinate
Post by Pumpkinate » Wed Jul 10, 2013 10:48 am
Hello
I am considering removing the primary catalytic converters and have a few queries. I'm aware that this requires removing the engine to gain access. I've heard that MRC are expecting to have some catless downpipes available for sale soon.
1. Would this make an appreciable difference to the cars performance? The car has a tune (APR) and no other modifications.
2. Would it be worthwhile also replacing the secondary cats with high-flow cats at the same time or is that overkill?
3. Would it hurt to remove the primary catalytic converters but not retune the ECU? In Australia as far as I'm aware noone does custom tuning on Audis, so all tunes are "off the shelf". APR will add a "testpipes file" if I go ahead but all this does is prevents catalytic converter error codes being displayed, the same mapping is kept. Obviously, its always better to get the car tuned for any changes in hardware, but if you can't would it do any damage to de-cat and not retune?
Cheers,
Steve
2010 RS6 APR tuned
2007 Jaguar XJR
2008 Subaru Forester XT
Trups
Trader (Expired)
Re: Removing catalytic converters
Post by Trups » Wed Jul 10, 2013 11:41 am
Speak to perthRS6, he has a 2 maps on his RS6 and he is in OZ, removing the primary cat will need to be coded into the map to stop the EML coming on.
taking that out it would be worth while getting a stage 2 map.
TBl
Post by TBl » Thu Jul 11, 2013 3:37 pm
Combination of removal of primary cats, installation of high flow secondary cats and custom-made 3'' exhaust in my case resulted in 50 BHP gain across the revs. The car felt considerably faster but also MUCH louder. I'd advise to test one before doing so in own car as it is pain in the ass to get back to stock.
Best - T
RS6 C6 Sedan 857PS tuned by Sportmile (as of now ;-) - work in progress)
RS4 B7 Sedan TTS Supercharged 621PS (for sale)
Radical SR3 RS 1500
Pumpkinate
Post by Pumpkinate » Sat Jul 13, 2013 7:49 am
Trups wrote:Speak to perthRS6, he has a 2 maps on his RS6 and he is in OZ, removing the primary cat will need to be coded into the map to stop the EML coming on.
Thanks Trups, I'll contact perthRS6. I can get the software upgrade to prevent the car throwing codes for $250.
I would ideally like to get a stage 2 map if I went ahead. C6NVS suggested getting a distance tune with Viper which sounds promising.
2010 RS6 APR tuned
2007 Jaguar XJR
Pumpkinate
Post by Pumpkinate » Sat Jul 13, 2013 7:52 am
TBl wrote:Combination of removal of primary cats, installation of high flow secondary cats and custom-made 3'' exhaust in my case resulted in 50 BHP gain across the revs. The car felt considerably faster but also MUCH louder. I'd advise to test one before doing so in own car as it is pain in the ass to get back to stock.
Best - T
Thanks TBl, I wonder if most of the noise increase was from the catback exhaust? I guess removing the primary cat only will still increase noise. Thats a good increase you got, was that with a retune or just the exhaust system changes?
2010 RS6 APR tuned
2007 Jaguar XJR
TBl
Post by TBl » Tue Jul 16, 2013 2:44 pm
it was 50bhp across the band just due to exhaust system change except for the peak power (c. 6500rpm) where the difference was smaller (can't remember exactly now). After retune it was 50bhp on peak revs as well.
Radical SR3 RS 1500
