I had the full black optic kit retro fitted by Audi. Parts came to £800 iirc.
You can then sell the front grill and window trim (if removed carefully) to claw money back.
Oem only way to go...
As above wrap can damage the ali trim... If your trim is water damaged/marked then this may be a good solution.
Optics - Paint or Wrap?
Re: Optics - Paint or Wrap?
Its more marked up and quite difficult to get it looking like new.
I prefere the blacked out look, so this is the main reason for a wrap.
I had a quote to wrap my door trim only recently at £60 which i was quite happy with.
Might get it done once i have my RS6 grill fitted.
any of you tried to remove vinyl off the silver trim when its been on there for a year or so? Good luck
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
I used plastidip on my plate filler on my B7 S4, and it had the texture you're referring to. Was kind of a rough surface.-Boosted- wrote:I went with the wrap as I did not want a permanent change (paint) or the texture of plastidip. I'm still debating on whether or not to wrap the mirrors.
Then I read a DIY that said
a) keep the cans warm before and during use (place in a basin of hot water for 15 mins before and between coats)
b) spray from 4-5 inches, rather than from farther away
Having done that, I have no texture. Just did this with my grille surround, on the aluminium.
It should be noted that I also peeled the old plastidip from my filler plate and it came off reasonably easy (after 4 years) with no damage to the plastic underneath. Just pealed off in about 15 minutes. If you do more coats it comes off even easier.
Good to know, I may try that in the future....sakimano wrote:I used plastidip on my plate filler on my B7 S4, and it had the texture you're referring to. Was kind of a rough surface.-Boosted- wrote:I went with the wrap as I did not want a permanent change (paint) or the texture of plastidip. I'm still debating on whether or not to wrap the mirrors.
Thanks, Bill
2007 Mugello Blue RS4
Users browsing this forum: Google [Bot] and 121 guests
