Nitrogen in your tyres?
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
vw_nutta
Post by vw_nutta » Sat Nov 06, 2004 3:32 pm
when I was ringing around, one garage said they offered a service to fill your tyres with nitrogen ( I think that was the gas they said), he said it means your tyres will never lose pressure and this results in better tyre grip.
Is this true? Anyone tried this or heard of it?
The garage is very reputable and not shoddy at all, so I kinda think he must be telling the truth.
[img]modules/pnCPG/Coppermine/albums/userpics/11703/rs246_thmb_S4front.jpg[/img]
tricky
Post by tricky » Sat Nov 06, 2004 4:22 pm
Given that the majority of our atmosphere is in fact made up of nitrogen, I'm not entirely sure how removing the remaining elements would prevent pressure loss and improve grip. Unless improved grip was as a consequence of no pressure loss. Get them to give you the low down, I'd love to hear it!
Morpheous
Post by Morpheous » Sat Nov 06, 2004 7:38 pm
Think what they are referring to is nitrogen filled tyres will remain at the same pressure regardless of temperature.
With normal compressed air, as tyres heat up, the pressure inside the tyre increases. This is why you should not set your pressures after blasting down the motorway for hours, cos next morning when cold, the pressure will have reduced. Not that much of a prob unless U got tyre pressure monitoring i.e. RS6 when the warning light comes on saying loss of pressure.
As to NEVER loosing pressure is a bit misleading cos u can still get punctures.
BRETTCOLLINS
Post by BRETTCOLLINS » Sat Nov 06, 2004 10:09 pm
been running my S4 tyres on nitrogen for six months now, have found that all tyres have stayed at the same pressure (36 psi) seems to work for me.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Dippy
Post by Dippy » Mon Nov 08, 2004 2:00 pm
Morpheous wrote:Think what they are referring to is nitrogen filled tyres will remain at the same pressure regardless of temperature.
I always check my tyre pressures cold. So how much does a tyre pressure typically rise by when hot? Presumably the idea of setting the cold pressure to a certain value is so that it is 'correct' when hot?
2001 Silver S4 Avant
jonno1
Post by jonno1 » Mon Nov 08, 2004 2:09 pm
Filled mine with Helium. Apparently my car is somewhere over the Atlantic at the moment. :roll:
JonS
2000 Ming Blue Avant, Tanoga Short Shift, Revo, RS4 gearbox (not by choice), RS4 Wheels, Eibach Springs, Forge DVs = Happy Days
jeffw
Post by jeffw » Wed Nov 10, 2004 2:49 pm
I think you'll find that it actually has to do with the water vapour that is present in normal compressed air. Increases of temperature will change the pressure due to this water vapour. It is common to use inert gases (Helium, Nitrogen etc) for tyres in racing circles to reduce this change in pressure. You'll need to have your tyres purged to get the maximum benefit.
Nordschleife
Post by Nordschleife » Wed Nov 10, 2004 7:55 pm
Most race series regulations today exclude the use of anything other than compressed air for the tyres. This is fine as you only need one set of bottles for the jacks, stutter guns and tyre inflation. Extra N bottles would just be another thing to lug around and a pia - but if N is not prohibited in your race series use it, stable pressures are much easier when it comes to extracting the final few .01 sec
DavidT
Post by DavidT » Thu Nov 11, 2004 12:46 am
4-6 PSI, depending on tyre type and 'use' is my experience.
I set mine at 38psi before leaving on the French/rs246 Le-Mans trip with outside temp 12c and checked them there at 1c and they were 36 psi :o so I blew them up. Next time I checked them at home they were 41psi :o :o
DavidT
Post by DavidT » Thu Nov 11, 2004 12:47 am
Yes but can you laugh about it ?
Nordschleife
Post by Nordschleife » Thu Nov 11, 2004 8:09 pm
that explains the squeaky exhaust note
TarmacTerrorist
Post by TarmacTerrorist » Thu Nov 11, 2004 8:52 pm
made me chuckle!
Too much is bad.
Plenty is better.
Users browsing this forum: No registered users and 55 guests
