Before I bought the RS6, I was considering buying a C6 A6 3.0TDi Avant and spotted these 19s cheap so snapped them up.
Now that I have the RS6, I'll use them as winter wheels. I just need some spacers and bolts now.
MG
While I've got a full stock car that's being driven 200-300 miles a week... it's nice to have it running exactly as Audi intended.bam_bam wrote:Get it mapped out, it's superfluous anyways.
Good man, but if you'd wanted to have it running as Audi intending, you'd not be running on DRC... oh wait...RS2 wrote:While I've got a full stock car that's being driven 200-300 miles a week... it's nice to have it running exactly as Audi intended.bam_bam wrote:Get it mapped out, it's superfluous anyways.
Once I get to the stage of being able to play with it, I'll probably remove some of the cats, remove the secondary air system and get it tuned at the same time.
MG
Lol... good point. I didn't remove it!bam_bam wrote:Good man, but if you'd wanted to have it running as Audi intending, you'd not be running on DRC... oh wait...RS2 wrote:While I've got a full stock car that's being driven 200-300 miles a week... it's nice to have it running exactly as Audi intended.bam_bam wrote:Get it mapped out, it's superfluous anyways.
MG
Thanks for the measurements. I was expecting more of a difference.ahoooga wrote:On standard original 19 rims ( 255/35/19 tyres) with stock/original drc suspension
from bottom of the rim , between the tyre and the rim
offside wheel is 61cm , nearside wheel 62cm
measured thru the centreline of the wheel
offside front @ 61cm
I believe this is the case. My bump stops are in virgin condition.RS2 wrote:ahoooga wrote: Re coil bind... if Bilstein have designed a coil over set (PSS9) that can go into coil bind before the bump stops are active... I think a lot less of them!
Hmmm... I got the wheels off today and jet washed everything so that I could see more clearly whats going on.Shoppinit wrote:I believe this is the case. My bump stops are in virgin condition.RS2 wrote:ahoooga wrote: Re coil bind... if Bilstein have designed a coil over set (PSS9) that can go into coil bind before the bump stops are active... I think a lot less of them!
Users browsing this forum: No registered users and 62 guests
