How to remove manifold link arms?
TonyHayers
Post by TonyHayers » Fri Jun 21, 2013 10:57 am
I'm doing a port and polish on a second intake manifold that I bought. The link arms on this one don't look as good as the ones on my existing manifold so I'd like to swap them when I fit it, but I can't see how to remove the flap pivot arm so they can come out. It must be possible since someone (034 motorsport or JHM) sell aftermarket machined replacements.
Anyone done this?
06 Phantom Black Saloon:
^ GONE :cry:
caldy
Re: How to remove manifold link arms?
Post by caldy » Fri Jun 21, 2013 11:14 am
Yup albeit a long time ago.
Knock through the 16 core plugs allowing access to the 16 screws holding the vanes to the shaft. Remove these and the vanes.
I think you then prise off the cap covering the end of the shaft and drift it out.
I sourced new shaft bearings and core plugs for re-fitting.
You gonna re-fit the vanes or leave them out? You already have a cold air feed and you may have removed the secondary air injection pump, in which case you don't need the vanes or the actuating arms as their presence will have been 'mapped-out'.
RS4 B7 Phantom Black
TonyHayers
Post by TonyHayers » Fri Jun 21, 2013 11:42 am
caldy wrote:Yup albeit a long time ago.
Hi caldy - sorry, should have said, I've removed the flaps already - managed to do it without removing core plugs by using a very low profile ratchet. I just can't see how to take the shaft out. Is it held in by friction or do the slotted ends screw out?
I'm not going to refit the flaps, but am thinking of leaving the shaft to rotate freely. Will be getting a remap once I've done the manifold prep and carbon clean.
^ GONE :cry:
TonyHayers
Post by TonyHayers » Fri Jun 21, 2013 11:47 am
Just posting some photos of the ends of the shaft. One side has the slotted bit each end and the other side has one slotted end and some sort of cap (first picture).
^ GONE :cry:
adsgreen
Post by adsgreen » Fri Jun 21, 2013 1:52 pm
slotted ends look like position sensor mounts - I'd be surprised if it was around there.
Doubt it would unscrew as the arms must be mounted somehow. I would expect turning it would break the arms.
What about pair of pliers on the slot and pulling?
caldy
Post by caldy » Fri Jun 21, 2013 2:12 pm
I think if you gently tap on the opposite end to the actuating arm, the shaft should drift out.
TonyHayers
Post by TonyHayers » Fri Jun 21, 2013 2:19 pm
Cheers chaps, will give it a try tonight.
^ GONE :cry:
adsgreen
Post by adsgreen » Fri Jun 21, 2013 4:25 pm
TonyHayers
Post by TonyHayers » Fri Jun 21, 2013 4:46 pm
Haha. I actually have a kilogram of thermite in my garage (long story). That might shift it.
^ GONE :cry:
adsgreen
Post by adsgreen » Fri Jun 21, 2013 5:35 pm
Try putting some on the bonnet of a car of somebody you don't like very much. The fireworks are fantastic :)
TonyHayers
Post by TonyHayers » Fri Jun 21, 2013 11:31 pm
hrm, gently tapping didn't work. Don't want to give it too much welly in case I damage bearings/seals :/
^ GONE :cry:
billq
Post by billq » Sat Jun 22, 2013 2:50 am
There are black tab things that line the shaft up.
They pull straight out.
Circled in blue..
TonyHayers
Post by TonyHayers » Sat Jun 22, 2013 2:24 pm
billq - you utter hero!
For anyone else in future, pull the black plugs out and tap gently on the shaft towards the flap end.
^ GONE :cry:
adsgreen
Post by adsgreen » Sat Jun 22, 2013 8:34 pm
TonyHayers wrote:pull the black plugs out and tap gently on the shaft towards the flap end.
<fnarr>
TonyHayers
Post by TonyHayers » Tue Jun 25, 2013 2:10 pm
<fnarr>
I was expecting somebody to comment on that :) ...
Bit of an update if anyone's interested. Porting is going well, can remove quite a bit of casting imperfections. Started with dremel, but by far the best tool I've found for doing the trumpets is a 50mm x 20mm abrasive flap wheel on my regular electric drill (cordless isn't fast enough). The 50mm wheel *just about* fits in the trumpet and does a really nice job of smoothing out. Because it's a good fit, you can get a nice even shape across all trumpets.
I'm not sure whether I'm going to attempt to grind out the "step" in the runners before the flap shaft. Seems to me that it nicely guides the incoming air over the potentially turbulent flap mechanism. I can see now why people lock the flap shaft, since that leaves it completely flat.
It looks quite awkward to do a really good job. Not sure whether to gamble :) this is only a spare manifold, but things are going well so far!
^ GONE :cry:
Users browsing this forum: No registered users and 95 guests
