20" Rotors on a sprint blue avant,pics anyone?
Searched on here but cant find pics but im sure ive seen some ? If anyone has can they post up please?
Re: 20" Rotors on a sprint blue avant,pics anyone?
Not seen them on bluey before. When I was looking for pics all I found was a white avant and 2 grey saloons. Obviously you can add mine to the list now.
Just look at Jules car and squint
Not sure if they're 20", but this shows the rotors on a blue avant.
S5 Supercharged V8 Coupe - Meteor Grey / Magma
TTS Supercharger (601PS / 675Nm) | Capristo Valved Exhaust | KW DDC Coilovers | JHM Short-Throw Shifter | HRE P104 21x10.5" + PSS
Ceramic Brakes (R8 GT Front / S7 Rear) | RS5 bootlid | Rieger S5 bumper | Rieger Sideskirts | RS5 grille | SPC adjustable UCA
H&R ARB kit | custom stereo & more | Fuelly | >> click for build thread << | Facebook Page
- Graeme4130
- Graeme4130
Ok, actually now I look at it they to look a little bigger. I'll blame my small iPhone screen
Which model are they off to get 20's in that style ?
C6 I suspect.
They look more like 19s and more importantly they don't have the right offset for an RS4 so are much less concave.Cuppa wrote:Not sure if they're 20", but this shows the rotors on a blue avant.
The RS5 Rotors (ET26) have the smallest amount of clearance on the front calipers. It is so close as I was turning the wheel (by hand) to check I actually thought it was going to clip them.
Jules' saloon with white rotors:
http://forum.rs246.com/viewtopic.php?f= ... 35#p587877
Thanks mike,what adapters are required? cost?
As the centre bore of the A5/RS5 is bigger than the size of the B7 one, a wheel made for the A5/RS5 will have a bigger hole in the centre of the wheel. This means you can still use an Rs5 wheel on a B7 but if you don't fit it dead centre you will get vibration at speed. But, if you get a spigot it basically makes the hole in the wheel a bit smaller so it is a snug fit on the RS4 hub.
Very cheap and easy to fit. You have 2 choices either the plastic versions or the metal ones. I bought both but the metal ones were too tight and would have needed hammeringto make them fit. I clearly didn't want to start hammering the wheel, so I ended up using the plastic ones. They fitted no problems.
Metal ones:
http://www.ebay.co.uk/itm/Conversion-sp ... 697wt_1161
They look better than the metal ones I bought, but I'd still stick with plastic.
Plastic:
http://www.ebay.co.uk/itm/SPIGOT-RINGS- ... 175wt_1399
As you can see the plastic ones are a fiver and they actually work really well.
FYI The RS4 centre bore size is 57.1mm and the Rs5 is 66.6mm.
Metal ones:
Plastic:
- Spacecowboy
Re: AW: 20" Rotors on a sprint blue avant,pics anyone?
here some pics from a german board member...
sprint blue and rotors... epic !
I love my wheels!
Users browsing this forum: No registered users and 145 guests
