20" Rotors on a sprint blue avant,pics anyone?
lengster1
Post by lengster1 » Thu Jun 13, 2013 9:49 am
Searched on here but cant find pics but im sure ive seen some ? If anyone has can they post up please?
Re: 20" Rotors on a sprint blue avant,pics anyone?
Post by MikeFish » Thu Jun 13, 2013 12:29 pm
Not seen them on bluey before. When I was looking for pics all I found was a white avant and 2 grey saloons. Obviously you can add mine to the list now.
Rick_RS4
Post by Rick_RS4 » Thu Jun 13, 2013 12:54 pm
Just look at Jules car and squint
Stoffle32
Post by Stoffle32 » Thu Jun 13, 2013 3:31 pm
this one is on the OEM 20" Rs4 rims Image
Cuppa
Post by Cuppa » Thu Jun 13, 2013 3:44 pm
Not sure if they're 20", but this shows the rotors on a blue avant.
S5 Supercharged V8 Coupe - Meteor Grey / Magma
TTS Supercharger (601PS / 675Nm) | Capristo Valved Exhaust | KW DDC Coilovers | JHM Short-Throw Shifter | HRE P104 21x10.5" + PSS
Ceramic Brakes (R8 GT Front / S7 Rear) | RS5 bootlid | Rieger S5 bumper | Rieger Sideskirts | RS5 grille | SPC adjustable UCA
H&R ARB kit | custom stereo & more |
Fuelly | >> click for build thread << | Facebook Page
Graeme4130
Post by Graeme4130 » Thu Jun 13, 2013 3:45 pm
Stoffle32 wrote:this one is on the OEM 20" Rs4 rims Image
I think they're 19", no ?
Stoffle32
Post by Stoffle32 » Thu Jun 13, 2013 4:22 pm
no its my mates car, he has 20's and im sure this pic was taken when he had them installed with 5mm front spacers
Graeme4130
Post by Graeme4130 » Thu Jun 13, 2013 4:38 pm
Ok, actually now I look at it they to look a little bigger. I'll blame my small iPhone screen
Which model are they off to get 20's in that style ?
doodlebug
Post by doodlebug » Thu Jun 13, 2013 4:59 pm
C6 I suspect.
Post by MikeFish » Thu Jun 13, 2013 5:25 pm
Cuppa wrote:Not sure if they're 20", but this shows the rotors on a blue avant.
They look more like 19s and more importantly they don't have the right offset for an RS4 so are much less concave.
The RS5 Rotors (ET26) have the smallest amount of clearance on the front calipers. It is so close as I was turning the wheel (by hand) to check I actually thought it was going to clip them.
Post by MikeFish » Thu Jun 13, 2013 9:52 pm
lengster1
Post by lengster1 » Thu Jun 13, 2013 10:08 pm
Thanks mike,what adapters are required? cost?
Post by MikeFish » Thu Jun 13, 2013 10:24 pm
As the centre bore of the A5/RS5 is bigger than the size of the B7 one, a wheel made for the A5/RS5 will have a bigger hole in the centre of the wheel. This means you can still use an Rs5 wheel on a B7 but if you don't fit it dead centre you will get vibration at speed. But, if you get a spigot it basically makes the hole in the wheel a bit smaller so it is a snug fit on the RS4 hub.
Very cheap and easy to fit. You have 2 choices either the plastic versions or the metal ones. I bought both but the metal ones were too tight and would have needed hammeringto make them fit. I clearly didn't want to start hammering the wheel, so I ended up using the plastic ones. They fitted no problems.
Metal ones:
http://www.ebay.co.uk/itm/Conversion-sp ... 697wt_1161
They look better than the metal ones I bought, but I'd still stick with plastic.
Plastic:
http://www.ebay.co.uk/itm/SPIGOT-RINGS- ... 175wt_1399
As you can see the plastic ones are a fiver and they actually work really well.
FYI The RS4 centre bore size is 57.1mm and the Rs5 is 66.6mm.
Spacecowboy
Re: AW: 20" Rotors on a sprint blue avant,pics anyone?
Post by Spacecowboy » Thu Jun 13, 2013 10:32 pm
here some pics from a german board member...
sprint blue and rotors... epic !
Best Regards
Daniel
rs4 v8 - h&r - 20"wheels - slow but looks awesome
http://www.rs-quattro.de
Post by MikeFish » Fri Jun 14, 2013 5:24 am
I love my wheels!
Users browsing this forum: No registered users and 119 guests
