Gearbox locked in gear
mavada
Re: Gearbox locked in gear
Post by mavada » Sat Jun 01, 2013 11:50 am
You could prob check your TCU for water damage.
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
RS6MTM
Post by RS6MTM » Sat Jun 01, 2013 11:50 am
No. 4 - Yes
It highlights in red whatever gear I choose
mavada
Post by mavada » Sat Jun 01, 2013 11:55 am
i seem to remember when my F125 switch went, i couldnt get it into reverse and all lights lit up, limp mode...had to restart it to get into reverse...
but you obviously havent got that error...
Yellow Koni's
Post by Shoppinit » Sat Jun 01, 2013 11:59 am
Would hurt to swap the TCU with someone else. If anyone's local? i would have thought that it would throw errors if it was faulty, though.
Sounds like it hasn't got enough pressure to get out of park, until you rev the nuts off it in which case it goes into 5th. At least in 5th you'd be able to pull it back. What happens if you rev it in D with your foot on the brake then try to pull it backwards once it's engaged 5th (not revving at this point, obviously).
RS6MTM
Post by RS6MTM » Sat Jun 01, 2013 12:08 pm
Im going to take a video of how it is now to hopefully give a better idea of what i'm trying! Now that you mention the 'reving to 5th' idea, it makes sense to me so ill try that later and see how i get on.
I dont think there is an issue with the TCU as before I parked the car, apart from the gearbox, everything was 100%. It has been in the garage for almost 2 months now so no water would have got into it between then and now
Post by Shoppinit » Sat Jun 01, 2013 12:13 pm
When I leave my car for a week or more then the pads bind to the disks and need quite a lot of force to break free. Just a thought.
/edit: when I put it away wet, that is.
RS6MTM
Post by RS6MTM » Sat Jun 01, 2013 12:28 pm
Have a view of this quick video below which hopefully shows my problem a bit better. I will try activating limp mode later (by revving a while) and see if I can pull the car back with my other car. Im on my own at the mo so I cant do it right now.
Post by Shoppinit » Sat Jun 01, 2013 12:30 pm
Have you been able to move the car forward? Even a little bit? I'm thinking of the binding brakes...
Checking out your vid now.
Post by Shoppinit » Sat Jun 01, 2013 12:32 pm
Cute cat.
Post by Shoppinit » Sat Jun 01, 2013 12:37 pm
OK, the revs go up to 1500. Is that you who stops there or do you feel resistance? I'm still thinking of binding brakes...
If you jack both rear wheels off the ground, can you turn one by hand?
RS6MTM
Post by RS6MTM » Sat Jun 01, 2013 12:43 pm
No, the issue isnt the brakes, its the gearbox. I will make another video now, showing me rev right up to 7,000RPM, with the same result. If it goes into Limp mode, I will try to push it back. I havent tried jacking the car up. I know there is about 5 mm movement between the brakes and the discs as I rock the car back and forward. But then its like hitting a brick wall and it will not move any further (gearbox locked in gear methinks).
@Shoppinit - Cat?!
Post by Shoppinit » Sat Jun 01, 2013 12:50 pm
Sounds like the car won't come out of park then.
Maybe your selector cable as come off / snapped.
Can you plug the Vagcom in and see what gear the gearbox thinks it is in when you move the selector? Might be an easy fix.
/edit: cat - the first link you posted showed me a cat before you fixed it.
ahoooga
Post by ahoooga » Sat Jun 01, 2013 12:55 pm
Can you confirm that the pads are clear on all FOUR wheels and not just the back axle ? Although its more likely to be the back axle being held on by the handbrake.
and did the first link have pussy in it and i missed it
bakustax
Post by bakustax » Sat Jun 01, 2013 12:57 pm
Lets hope it's not the brakes binding...if they suddenly un-bind themselves when you're in D with 7k on the rev counter it could be catastrophic(ly funny)
ahoooga
Post by ahoooga » Sat Jun 01, 2013 12:59 pm
But then he could sell the garage to McDonalds as a drive thru
