Great, cheers535dboy wrote:I hasn't quite established if that did that or not yet. It's how the mrs tends to drive it
The other bit is for the plastic key
Individual Setting
- Graeme4130
Re: Individual Setting
Has anyone worked out what the default setting is when starting up. I'm assuming Auto all round?
Irritating that if you you switch off in Dynamic or Individual it re-starts in another mode. It then takes the electronics about 30 secs to wake up before you can revert to setting you want. Ideally need a on/off MSport switch as per BMW for the Individual Mode.
Also it doesn't tell you what mode you are in on start up - the display indicates the mode you switched off in although not in it.
Also really needs a separate switch for the Sports Exhaust.
I agree with previous poster that Dynamic ride not that disastrous and I'm driving the car more in full dynamic mode - car seems much more sporty overall in this mode than my Individual Mode where I have everything on Dynamic except ride in Auto.
- Graeme4130
That's odd, as if I switch mine off in individual (and D), it starts back up in individual (and D)GHH123 wrote:Has anyone worked out what the default setting is when starting up. I'm assuming Auto all round?
I'll try a couple of other settings and let you know
Mine starts in individual if I turned the car off in individual - havent tried what happens if in dynamic. If I switch transmission to sport the flaps open and stay open (I have configured individual to dynamic for gearbox/exhaust), even if I put the gear lever back to auto. Agree that it would be nice for the exhaust to always be in sport if one wants it that way.
2013 RS4 Prism Silver
evodeansmith
It shouldn't be doing that bud. With the engine and gearbox setting in dynamic it should open the exhaust valves and keep them open whether you're in D,S or manual. I have to cycle back through to my individual setting each time I start the car to get the valve open, which is a pain in the arse.Graeme4130 wrote:Quick question if poss please :
In individual settings, I set engine to dynamic to open exhaust valves, but if I then drop the lever down to get the transmission from S to D, it then seems to close the exhaust valves again.. Anyone know if there'a a way I can get around this so I get the softer "D" gearchanges, but still sports exhaust ?
Also, does anyone know what the empty key shell is in the glovebox in the upper left in a special holder ?
The difference in tone should be noticeable at tickover. Try shifting from D - S at a standstill (foot on the brake) with the door open, it shouldn't change. If it does, I'd go and have it looked at. You can also hear the valve opening and closing with just the ignition on if you cycle through the settings, worth checking this way too.
No idea what the keyshell is, I'll take a look at mine when I'm back in the office.
On a side note, there might be a fuse for the valve as in the V8 Vantage. Might be worth having a look then you can just remove the fuse and have it open at all times.
- Graeme4130
I'll have a play and see later, but pretty sure it reverts to closed when in D, but if I go to manual or S it remains open. I;m doubting myself now, so I'll double checkevodeansmith wrote:It shouldn't be doing that bud. With the engine and gearbox setting in dynamic it should open the exhaust valves and keep them open whether you're in D,S or manual. I have to cycle back through to my individual setting each time I start the car to get the valve open, which is a pain in the arse.Graeme4130 wrote:Quick question if poss please :
Not sure about fuse removal like the V8V as quite like how quiet it is when closed for pottering around or doing the shopping. Also, wife is starting to ask when it's her turn to use it, so she'll want the quietest setting
Mine stays open in D
I've just done what dean said and there is no difference in tone between d and s
Currently :
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
Seat Ibiza excellence Lux!
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2017 AMG E class wagon
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2012 Audi RS4 (B8)
Mine always starts up in Dynamic or what ever i had it in when the engine goes off on start up gear mode D then push back on the gear stick for S and open the exhaust valves cant see any thing in the manual about this possibly a Vag Com ajustment???
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
- Graeme4130
Right, I've had a play with it this morning
If I turn it off in individual whilst in D(set as strg auto/eng dyn/susp comfort/diff auto), it'll start up in individual again, but with valves closed (apart from initial start up drama) and still in D. If I either reselect Individual setting or put the shift to S or manual, it'll then open the valves again and the sound changes
Dealer did say it has latest software update as car was only manuf'd 5wks ago, so maybe something new
It's not an issue for me anyway, but I'll check it with the dealer when it goes back in a couple of weeks for a snagging item on a bit of paint
Mine does exactly the same so I don't think it's a software issue. When you select S by pulling down on the lever do it again and it will go back into D but your exhaust valve will stay open. That's it really, but mine never starts up with the valve open and I always need to do the into S back into D procedure to open the valve.Graeme4130 wrote:Right, I've had a play with it this morning
2019 RS3 4 door - Gone
- Graeme4130
Oh good, ours are fine and it's everyone else'sRSphantom wrote:Mine does exactly the same so I don't think it's a software issue. When you select S by pulling down on the lever do it again and it will go back into D but your exhaust valve will stay open. That's it really, but mine never starts up with the valve open and I always need to do the into S back into D procedure to open the valve.Graeme4130 wrote:Right, I've had a play with it this morning
Yours is quite recent too RSPhantom, right ?
Dealer did say car had latest software, so it's just up to the others, with their old hat software, to catch up ! Haha
[/quote]Oh good, ours are fine and it's everyone else's
Dealer did say car had latest software, so it's just up to the others, with their old hat software, to catch up ! Haha[/quote]
Mine was build week 5 2013 so not sure how that compares to everybody else. I think there might be a bit of confusion around all this (but it just might be me getting the wrong end of the stick) but I think we might be taking about two diferent things here.
If the car's already started and running, your in either dynamic setting or individual with dynamic set for engine/gearbox, you have either put the gearbox into sport, pressed the driver select button to activate or gone into car settings on the MMI and pressed individual setting this will have opened the exhaust valve and as said before you should hear the note of the exhaust change. At that point if you pull the stronic down to sport again the gearbox should change from S to D but the exhaust valve should stay open.
After doing all of that you then stop, turn off the car and then start up again my car will be in the selected setting I had it in before in this case dynamic or individual but the exhaust valve will not be open. I need to do one of the above to get the valve to open again.
From what I've read I think everybody's is the same with the exception of one post which seems to indicate it always starts in Auto mode.
Anyway, forgot to say congrats on the motor, looks good with the optics and the V spokes. How are the buckets, was midly tempted but I find the supersport seats really good so the brain couldn't justify the extra.
- Graeme4130
yeah, I'm sure all are the same. I expect there's no change from car to car.
Buckets are really good. Supersport seats are very good too as I had them in demo car previously, but buckets are one of those things (like silver mirrors) that just seem to make the RS cars for me. They're basically identical to those I had in my B7 and although the rear leg room is compromised, it's a small amount better than my B7, so now slightly more suitable for 4 adults and with the rear plastic clam on them, better for my kids with dirty football trainers and all the associated grime they seem to grind into the back on the seats
Users browsing this forum: Google [Bot] and 118 guests
