Health check at mrc 309bhp vac issues and decoke
lengster1
Re: Health check at mrc 309bhp vac issues and decoke
Post by lengster1 » Fri May 17, 2013 11:42 pm
Most out there are only making 360-370 and that's not much for the weight,they need to be in good order and fettled to be a real high performance motor.
lengster1
Post by lengster1 » Fri May 17, 2013 11:43 pm
180 isn't bad but avants are faster :biggrin3:
Post by MikeFish » Sat May 18, 2013 10:42 am
lengster1 wrote:180 isn't bad but avants are faster :biggrin3:
But the dogs in the back won't like it!
Jamiestanton
Post by Jamiestanton » Sun May 19, 2013 12:02 pm
Ha ha yeh and the ladders on the roof may blow off
2006 black audi rs4 b7 mrc stage 2 stage 2 manifold de cats miltek coil overs light weight flywheel black optics 445bhp 470nm
Graze
Post by Graze » Tue May 21, 2013 12:44 pm
So my stock RS did 201.9kw or about 275 PS (if I got the conversion right)
I'm told that's pretty normal. Car has done 53,000km
Was planning on getting it carbon cleaned around the 60,000 km mark
These numbers are nothing like what I'm reading in this thread, should I do the carbon clean sooner?
Graze
Current
V12 Vantage S
Sold
2007 B7 RS4, Ibis white, 8mm spacers, carbon chin spoiler
2001 B5 RS4, Metallic Black, Neuspeed rear ARB, 275/30/19's + 10mm spacers on B7 RS4 wheels! 034 motor mounts, APR snub mount, JHM shortshifter, 18Z calipers & slotted rotors, custom FBSW
Post by MikeFish » Tue May 21, 2013 12:50 pm
Graze wrote:So my stock RS did 201.9kw or about 275 PS (if I got the conversion right)
Graze
275PS is way too low. I assume your 'RS' is a B7 RS4? Your problem is not carbon, I'd save your money and get somebody to look at your engine. Most likely a vacuum problem with power that low.
adsgreen
Post by adsgreen » Tue May 21, 2013 2:19 pm
I'm sure people have said that if the manifold flaps are well and truly stuck either due to carbon or vacuum then you'll get at most around 270-290ps.
But this will trip a mil light instantly...
billq
Post by billq » Tue May 21, 2013 3:14 pm
Graze
I think that is about right Graze. We measure power at the wheels where as these guys measure power at the flywheel (between you and me, it sounds like a bit of guess work as the engine isn't removed)
ArthurPE
Post by ArthurPE » Tue May 21, 2013 4:03 pm
graphs for wheel power, very accurate, all these guys do is independent dyno testing, some for type rating (DIN/ISO/TUV/EEC) for manufacturers
http://rototest-research.eu/popup/perfo ... artsID=769
car had 17000 miles on it, so it had dirty valves
http://rototest-research.eu/popup/perfo ... artsID=281
car had 600 miles, so was clean
clean 349 HP
dirty 333 HP
4.5% loss, but not all is due the deposits, I estimate tire wear had a lot to do with it
a car making 275 at the wheels has a lot more issues than carbon
Graze
Post by Graze » Wed May 22, 2013 8:20 am
Arthur
car runs well and pulls hard (although I haven't driven another B7 RS4)
what should i be looking for if you think it has other things wrong with it?
Graze
Current
V12 Vantage S
Sold
billq
Post by billq » Wed May 22, 2013 10:32 am
If those dyno charts a accurate, it appears they are only losing 15-20% through drive train loss.
Everything I have ever seen indicates awd cars lose roughly 30%.
ArthurPE
Post by ArthurPE » Wed May 22, 2013 4:11 pm
billq wrote:If those dyno charts a accurate, it appears they are only losing 15-20% through drive train loss.
they are accurate, that's all these guys do is dyno, not tune or anything else, just dyno
what have you 'seen''?
rated 420
making 340 (use ~ average)
losses = (420-340)/420 ~20%
which is what would be expected and is quite high
most 2wd lose 10-15%
no way is it losing 30% or 125 HP
the most I've seen on a dyno that actually measures losses is ~100HP (car had other issues) which is only 24% or so
30% is only possible with the brakes applied ;)
ArthurPE
Post by ArthurPE » Wed May 22, 2013 4:16 pm
Graze wrote:Arthur
Graze
do some 3k to 8k 3rd gear runs, maybe 3 to 5 of them
post the results
Graze
Post by Graze » Wed May 22, 2013 10:51 pm
Will try And find somewhere to do them without losing my licence - not easy around Brisbane
Graze
Current
V12 Vantage S
Sold
adsgreen
Post by adsgreen » Thu May 23, 2013 8:19 am
Graze wrote:Arthur
Graze
Vacuum system the obvious place to start.
I do think that a fair bit of the problems are resolved during cleaning when the silly 10p one way vacuum valve is changed.
Users browsing this forum: Google [Bot], Neuromancer and 105 guests
