Anyone tried H&R springs on theirs?
dan101smith
Post by dan101smith » Tue May 21, 2013 1:59 pm
I need to replace my front springs. I can either go with OEM from the dealer, or H&R to replace all of them. I've got new OEM shocks.
Has anyone tried the H&R springs? Do they actually drop it much? I'm not hugely bothered about lowering it, as a decent ride is more important! The only reason I'm considering them is that a set of 4 H&R costs only slightly more than two OEM...
ASC
Re: Anyone tried H&R springs on theirs?
Post by ASC » Tue May 21, 2013 3:43 pm
I have H&R's with stock shocks. Lowered 30mm all round, looks good and ride is good, far less barge-like, feels much tighter, bit harder but not bone crunching as the stock shocks keep it civil! :thumbs:
Current - 07 Sprint Blue RS4 Avant Black optics / Buckets / FBSW / MRC Stage 2 / De flapped Manifold / CAF / BMC filter / Decat / Non Res Miltek / Bilstein B16's / Tarox discs, pads and lines / H&R ARBs / 19x9.5 Ispiri ISR1 wheels / MPSS tyres / DTM carbon splitter
Previous - 06 Sprint Blue B7 S4 Avant JHM 91 tune / 2.5" Custom Cat-less DP's / Miltek Non Res Cat back / BMC filter / H&R springs / 19" Fox MS007 wheels/Good Year F1's / EBC TG discs / Yellow stuff pads
goose
Post by goose » Wed May 22, 2013 10:55 am
As ASC, i have the -30mm H&Rs with stock shocks and all is good.. altho i do ground my milltek quite a bit, as it hangs lower than a std exhaust :-O
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Jocky
Post by Jocky » Wed May 22, 2013 4:15 pm
Same here, got them with 10mm spacers all round and I love the stance. Handling is just a touch stiffer than stock but hardly noticeable. Let's face it the roads in this country are crap, if your hitting potholes it doesn't matter what your running, so you might as well look good doing it!
dan101smith
Post by dan101smith » Wed May 22, 2013 4:46 pm
Cheers guys.
I think I'm going to stick to OEM, though. Should still be significantly better than the worn springs that are on there now!
S4_kiwi
Post by S4_kiwi » Wed Jun 05, 2013 7:15 am
Good choice, I've got the H&Rs on mine and I really don't like them at all!
Far too firm for the rubbish roads where I live..
goose
Post by goose » Wed Jun 19, 2013 4:20 pm
quick heads-up.. continued use of -30mm H&R springs with std shocks and 10mm H&R rear spacers, and I've just had to replace the OSR wheel arch liner as the tyre had knocked out a retaining clip and the liner dropped onto the tyre and wore a huge hole in it!!
60 odd quid part, plus a bit of labour and the VAT and thankyou very much £140
goose
Current:
Past:
Jocky
Post by Jocky » Thu Jun 20, 2013 10:54 am
Are you bottoming out? I've got the exact same set up and never bottom out at the back (never really have anything heavy in the boot though). The front sometimes rubs if pushing on into a dip but otherwise have had no problems.
goose
Post by goose » Thu Jun 20, 2013 3:12 pm
Jocky wrote:Are you bottoming out? I've got the exact same set up and never bottom out at the back (never really have anything heavy in the boot though). The front sometimes rubs if pushing on into a dip but otherwise have had no problems.
i have a feeling i must have either hit a pot-hole really hard and the tyre banged the clip out.. or it was when i had a couple of my biffa mates in the car who play Defense for the Reading Renegades lol!
goose
Current:
Past:
randomshenans
Post by randomshenans » Sat Jan 11, 2014 8:12 pm
Anyone got a pic of stock vs 30mm drop? I have been offered a set :)
Users browsing this forum: No registered users and 9 guests
